I assume you know about using Zinc in the oil from now on?
Also, before placing your Summit order it wouldn't hurt to purchase a cam bolt lockingplate ($5). It mounts under the camshaft bolts, has tabs that bend down and lock the bolts from ever coming loose, cheap insurance.
Your new camshaft will come with a break-in lube packet. For a couple bucks you can buy a second packet and really grease the snot out of the new lifters / lobes. (critical)
I didn't say that. You stole my sentence. Few of those two piece timing covers will clear the short waterpump, too thick.
Your sentence was so well written I quoted it while retaining proper attribution to you. Anyway I put one on my small block and turned out fine when my own cam sent south. I'm not aware of the particulars with regard to water pumps, so possibly you can improve my recommendation with your own experience? I'll have to take a look at what's on my motor.
please do check.
not having to deal with the oil pan sealing would be great.
Two piece timing covers are the greatest invention since aluminum heads. But, on C3s you can hardly get a piece of paper between the pump and timing cover. Most of the 2 pc covers I have checked on, state: will not fit short W.P. ( too thick) Some have put spacers on the W.P. ports. Then your pulleys are off.
Unless you plan on changing the cam timing for different track conditions every weekend, a 2 pc cover would not be money well spent. You still have to pull the clutch-fan and W.P. anyway.
Two piece timing covers are the greatest invention since aluminum heads. But, on C3s you can hardly get a piece of paper between the pump and cover. Most of the 2 pc covers I have checked on state: will not fit short W.P. ( too thick) Some have put spacers on the W.P. ports. Then your pulleys are off.
thanks for replying.
I have a plan for a new motor.
going to be tricky satisfying cali smog tests.
so any easier method to change out cams
would be most welcome.
We so need to talk. I have been scheming the same thing.
Scrape, scrape, scrape... x100 I favor the Exhaust Opening, Intake Closing method of setting initial valve lash. Still, let's be sure to cross them off one by one...
25 minutes at 2000-2500 rpm. It's scary... I found myself stalling, checking and rechecking everything: fire extinguisher, carb primed, power to ignition, fluid levels...
I forgot to tighten the clamp on the smaller hose going to the intake manifold and had to briefly shutdown.
It was a cold-ish day. The temp stayed rock-steady at 180; the electric fan never needed to kick in. I had drilled some 1/8 holes in the thermostat flange. That seems to have improve the thermostat response.
To avoid dipping below 2000, I gave the idle speed screw a full turn in.
I added a bottle of zinc additive just for good measure and may add another once I change the oil and the filter.
I saw some puffs of smoke developing, but it seemed to come from under the exhaust header. It turns out there is an oil leak at the fuel pump - I have NO idea how I managed that.
Other than that it was uneventful. Oil pressure stayed at 35 psi.
The first minute or two sounded slightly cringe-worthy, but soon it settled down.
An automotive stethoscope and everything seemed to have that nice whirring sound. I could hear a small, rhythmic metallic tink. It didn't sound like a lifter but shared the same frequency. I am guessing that it is the ever so slightly bent pushrod that maybe brushing against the cylinder head's guide slot.
Very clever using a magnet instead of a longer bolt on the pump pushrod. Yes, those fuel pump mount gaskets like to show who's boss. Two gaskets=four surfaces to smear the Permatex. One out of four usually drip. But oil is a good driveway weed killer.
Absolutely add Zinc after the oil change. You are running flat tappets. You can pick a oil that has at least 800 ppm Zinc.
Everything looks good. You may be disappointed in a single plane on the street, but time will tell.
Mmm I am increasingly leaning toward a GM crate engine. I just need something reasonably comfortable
to drive. I’d rather not invest too much in this fellow. If it is really unbearable I’ll toss it out.
