Brother's 67 Convertible
Old Jun 5, 2018 | 08:59 PM
  #221
elwood13's Avatar
elwood13
Its just not as open as I would prefer...lol
Old Jun 5, 2018 | 10:09 PM
  #222
GUSTO14's Avatar
GUSTO14
Originally Posted by elwood13
Finally got the car in the garage, still waiting for New York to clear up the title fiasco and scraping out carpet glue is where I am at now. Going through some more of my brother's papers and receipts I found this paper and got excited thinking it was the numbers for the block that is in there now since the pad is clean. Well, one look on my block and this is not it as my number is GM 3858174. I'm wondering if this note is a motor he was looking at or was in the car when he bought it. It wouldn't have been original for this car and I don't even know if it is a corvette block. Here is what was on the paper.
Behind flywheel right side - SPECIAL H23 with 870 over 852 and the letter S below the H23
Back top left side- GM 3782870
1962-65 3782870 327cuin 250hp-375hp 2-bolt main, car, truck
Right side front - 5121522 F05I0HR and the I is not a 1.
HR 1965 327 300hp 4 barrel Pwrglide, h/p, a/c
HR was used in the 1965 Corvette with 300hp, auto trans, and A/C, so it could potentially be a Corvette engine, especially if the "5" at the beginning of the VIN seq is really an S
Good luck... GUSTO
Old Jun 5, 2018 | 10:21 PM
  #223
elwood13's Avatar
elwood13
Thanks Gusto. I wondered what that went to. I don't have it and just wonder why he wrote it down and stuck it old receipts. With my brother, who knows. What scares me more is if he took the build sheet off the tank and stuck in some random place and I threw it away. I tried to keep all the car paperwork, and it was mostly together, but I found the title in a random box in a random spiral notebook. The first load of papers that went to the dump weighed 1100-1200 pounds so I may very well have missed something. He always said it was a big block car and was confident. Don't know if he figured it out like you guys did or had the build sheet.
Old Jun 5, 2018 | 10:41 PM
  #224
shemp's Avatar
shemp
Originally Posted by tbarb
It seems this is originally a big block car..
What? How do you think that?
Old Jun 5, 2018 | 10:51 PM
  #225
elwood13's Avatar
elwood13
I'm just going with what I was told here with the way some things are laid out in the car. I have been told this was probably a 390 car based off of instrument cluster, rear sway bar, rear end, front sway bar thickness, big block radiator mounts, the way a wire is attached to the firewall, driveshaft bolts and would have to go back to the beginning to see what else was listed. If im wrong, let me know because I learn something new about this car all the time.
Old Jun 5, 2018 | 10:52 PM
  #226
elwood13's Avatar
elwood13
Sorry, just noticed that was directed at tbarb.
Old Jun 9, 2018 | 02:15 PM
  #227
elwood13's Avatar
elwood13
Well here is the 30 plus year old prestone antifreeze. The particles blew in from the wind. Could not find a trim tag on the radiator but it is a four core. I would consider yesterday as the first official day on the start of restoration. Should I start a new thread for that?
Old Jun 9, 2018 | 03:06 PM
  #228
tbarb's Avatar
tbarb
The radiator tanks look good, you need to let a good radiator shop look at the core but there does not appear to be deposits inside. My suggestion for the time being is to cap all openings tight and store the radiator with it full to the top with 50/50 antifreeze and distilled water, keep the air off of the inside.
If someone directed a question to me about why I believe your car is originally a big block car that got answered in the first dozen or so posts. I don't believe i'm mistaken but you learn something new every day.
Old Jun 9, 2018 | 03:38 PM
  #229
elwood13's Avatar
elwood13
Thanks. I plan on going with a Dewitt’s but keeping the original. How should I store it then? I really don’t want to keep it full of antifreeze unless I have to. Or would it be best to have it gone through and then store it?
Old Jun 9, 2018 | 03:59 PM
  #230
tbarb's Avatar
tbarb
If it was mine i would have it looked at and use it. if you put a big motor in the car and build it stock use all the seals etc. You will probably be fine.
From the pictures it looks to be in nice shape, if there are any issues after having someone look at it you can always get the DeWitt but you may be surprised.
Old Jun 9, 2018 | 07:06 PM
  #231
elwood13's Avatar
elwood13
I will be going with a big block, just not sure if 427 or 454. All depends on the best deal I can find. I guess I could still put an electric fan on if I decide. Here's a new question. Is the crossmember in front of the engine supposed to have two humps in it? Also notice that the vertical bracket by the second hump seems high. The vertical bracket on the driver side is flush.
Old Jun 9, 2018 | 07:24 PM
  #232
tbarb's Avatar
tbarb
I can't answer your question about the second depression in the crossmember except I will look at my 67 tomorrow, I don't believe it belongs there but someone here may know.
FWIW, to maximize your cars value consider a 427 with a cast date prior to the car build date and build it stock. It's your car and I respect whatever you decide to do but I read so many stories here where engines, brakes etc. are changed and not engineered correctly and the owners have nothing but problems.
If you want to go fast buy a new Corvette, these cars are old school now a days.
Old Jun 9, 2018 | 07:52 PM
  #233
elwood13's Avatar
elwood13
I agree with you but it’s just insane to me the amount people are asking for a period correct block. That’s why I was considering a 454 also. I’m in no rush for the engine right now so hopefully I can find a 427 deal somewhere.
Old Jun 9, 2018 | 10:24 PM
  #234
GUSTO14's Avatar
GUSTO14
Default Engine is offset to passenger side
You need to keep in mind that the engine in these cars does not sit in the center of the engine compartment, it is offset slightly to the passenger side. Someone here will recall the exact amount, right now it has slipped my mind.
Because it is offset to the passenger side, the larger depression of the two is also offset to the passenger side to clear the Big Block crank pulley's. This has the effect of making the rear, lower control arm pickup point appear to be sticking above the crossmember on that side. In reality the upper surface of the crossmember on that side is lower than the driver's side because of how the tooling shaped the crossmember depressions.
The bottom line is that the crossmember is probably just as it left the factory.
Good luck... GUSTO
Old Jun 9, 2018 | 10:53 PM
  #235
elwood13's Avatar
elwood13
Thank you Gustov. I didn’t even notice the offset and now as I look at it it is as plain as day. Any idea what the second smaller depression is for and was this crossmember used in all cars or just big blocks?
Old Jun 10, 2018 | 10:31 AM
  #236
tbarb's Avatar
tbarb
I just looked at my 67 corvette and want to put your mind at ease, the second depression you are concerned about is on my crossmember also.
Old Jun 10, 2018 | 10:35 AM
  #237
elwood13's Avatar
elwood13
Thanks tbarb. My wife now thinks we should go period correct on the motor. Looks like I will be saving for awhile.
To Brother's 67 Convertible
Old Jun 10, 2018 | 11:08 AM
  #238
ptjsk's Avatar
ptjsk
LOL! Can't go wrong with that Chris!
Pat
Old Jun 10, 2018 | 11:32 AM
  #239
elwood13's Avatar
elwood13
Thanks Pat. I thinks she really stated Pat should trade motors in the Nomad with me.
Old Jun 10, 2018 | 01:38 PM
  #240
tuxnharley's Avatar
tuxnharley
It sounds like both the car and the wife are keepers!
