Another problem...damm it!
2008 C6..My passenger side low beam light will work if i turn it off then back on but not for long.I checked the fuse today #19 and it is good,so it must be the bulb?....My question is how do I get to the back side to change the bulb?..Thanks Guys.
Cherokee Nation (10-15-2017)
Race Car Tech
Could it also be the ballast ?
Dave
Dave
Landru (10-16-2017)
Probably because they are a PITA to R&R. You have to remove 2 small brass screws, have almost zero room to get torx screw driver and your fingers in there at the same time. Drop one of the screws and your in deep do do as NOBODY has spares. Plus you have to move the bracket to the new bulb.
The low beam high intensity discharge lighting
system operates at a very high voltage. If you
try to service any of the system components,
you could be seriously injured. Have your
dealer/retailer or a qualified technician
service them.
service them.
Cherokee Nation (10-16-2017)
OP, the bulb is not hard to change, but the screws that hold it in place require a torx. The screws are easy to lose also, and not easy to find.
It's pretty simple. Rotate the front wheel out of the way, remove the access cover in front of the wheel by removing the reusable push/pull clips. Keep a telescoping magnet close by the tip of your screwdriver to catch the retaining screw when removing the bulb. Of course don't touch the replacement bulbs glass surface with your fingers.
when i get home, i will see where i got my bulbs from. cant remember off the top of my head..
maybe morimoto,
http://www.morimotohid.com/hid-bulbs...reselect=49478
edit, i got mine from The Retrofit Source, and did 5500k to make them more white
https://www.theretrofitsource.com/bu...reselect=49478
maybe morimoto,
Cherokee Nation (10-17-2017)
