[C1] Rack & Pinion Manufacturer/Steeroids Brand
Old 01-18-2018, 05:11 PM
Eric Sakai
Eric Sakai's Avatar
Default Rack & Pinion Manufacturer/Steeroids Brand
Does anyone know who manufacturers the rack and pinion used by Steeroids?
I wanted to know if its GM or something else.
For example, I see that Jim Meyers uses Mustang rack & pinion for their bolt-on IFS.
Thanks,
Eric
Old 01-18-2018, 09:42 PM
bj1k
bj1k's Avatar
Thanks,
Eric
I just installed the Steeroids unit in my 57 and I emailed the company with that exact question . I wanted to know what I had so if replacement is necessary I could buy a new replacement anywhere that I chose . They wouldn't answer the question , just said that the rack that they use had the specs modified for their particular application . True or not ? You decide ! I just believe that it is a stock rack that they hope to gouge you for replacement . But for what it is ?
Old 01-19-2018, 03:11 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
this is what a mustang2/tbird power rack looks like
Bill
Old 01-19-2018, 05:58 PM
Plasticman
Plasticman's Avatar
According to Steeroids, below is the C1 Steeroids kit. You see the long tie rods, which appear to bolt to a center bracket, which then bolts (via the center 2 bolts) on the rack. The center portion of the rack moves, rather than the ends like Bill's Mustang / T-Bird rack.
This allows the use of the long tie rods to match the pivot angles and length of the stock A-arms, to prevent (or at least limit) bump steer.
As to where it was used OEM wise, don't have a clue.
Plasticman
Old 01-20-2018, 04:00 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
interesting John.... I can't imagine what would use that kind of 'moving' rack, so maybe it is proprietary
Bill
Old 01-20-2018, 08:39 PM
bj1k
bj1k's Avatar
Plasticman
That is the rack that came with my 57 kit but the frame brackets are different and the center bracket is much longer. These are the first racks that I have seen that have the tie rods connecting in the center. Most just move from the ends of the rack. My tie rod ends at the wheel ends do have an odd looking long bolt connecting them which are adjustable that they claim can reduce or eliminate bump steer.
Old 01-22-2018, 08:38 AM
62vetteman
62vetteman's Avatar
The Steeroid Rack looks very similar to a '85 to '94 Chevy Cavalier Rack.
Old 01-22-2018, 08:57 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
yep it does....
thanks
Bill
To Rack & Pinion Manufacturer/Steeroids Brand
Quick Reply: [C1] Rack & Pinion Manufacturer/Steeroids Brand
