HELP can't get my car out of neutral
Old 03-19-2018, 05:53 PM
prestige6
prestige6's Avatar
Default HELP can't get my car out of neutral
Went to start my 2007 base conv. car, so I can use it tomorrow. Started up, but it is stuck in neutral. Worked fine when I parked it less than 3 weeks ago. Help what's the problem...
Went out and started it off an on a few times. Started to work correctly... What causes this??
Old 03-19-2018, 07:01 PM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,843 Likes on 1,801 Posts
Type of transmission would be helpful.
Old 03-19-2018, 07:33 PM
dpigguy
dpigguy's Avatar
If an auto, likely the shift cable is hanging up or the lock out switch is the culprit. Search forum for conversations on this issue as it’s been around for a long time.
Old 03-20-2018, 06:51 AM
prestige6
prestige6's Avatar
6 speed manual.
Old 03-20-2018, 09:39 AM
RogerRamjet21
RogerRamjet21's Avatar
Originally Posted by prestige6
6 speed manual.
If it shifts into all the gears (except reverse) normally when the engine is not running, the it could be master or slave clutch cylinder(s).
Old 03-20-2018, 11:53 AM
dpigguy
dpigguy's Avatar
Manual issue could be with clutch cylinders or a linkage problem. Can you shift gears with the car running and clutch depressed? Does the clutch feel normal or is it harder/softer than normal? Check the fluid reservoir and make sure it is full. There was a tsb on the clutch master cylinder but your car may not covered after 10 years.
Old 03-20-2018, 12:02 PM
ruxvette
Support Corvetteforum!
ruxvette's Avatar
Received 3,629 Likes on 2,349 Posts
2016 C6 of Year Finalist
A little more info might help.
With the engine shut off does the stick move through the gears?
Is the clutch pedal on the floor?
With the engine running and the clutch depressed does the stick move through the gears?
With the engine running and the stick in the first gear position is it in neutral when you let out the clutch?
Old 03-20-2018, 12:32 PM
prestige6
prestige6's Avatar
It's working correctly now. When this happened the clutch pedal felt normal. Was stuck in neutral weather the car was running or not. After a few start ups and shut downs, it starting working correctly shifting through the gears with no problem.
Old 03-20-2018, 01:28 PM
bartsky
bartsky's Avatar
Would not hurt to make sure clutch fluid is good and clean.
Old 03-21-2018, 04:09 PM
I say NA to boost
I say NA to boost's Avatar
Typically when a manual car is stuck in neutral, its because the clutch can't fully disengage from the flywheel. This can happen for a few reasons. The most common is a lack of hydraulic fluid in the reservoir allowing the piston to suck in air. But it could also be because of a leak elsewhere allowing air in. As well a bad shift linkage could simulate this problem. If you can pump the clutch a few times and then get it into gear, it indicates that there is air in the lines. Since the system is meant to be contained, that could indicate that theres a leak somewhere; hopefully somewhere easy to access.
To HELP can't get my car out of neutral
Quick Reply: HELP can't get my car out of neutral
