Electric Oil Pressure Gauge
Old 06-28-2018, 04:52 PM
MBrianB
MBrianB's Avatar
Default Electric Oil Pressure Gauge
Is there an electric gauge available for a '72 that looks original?
Old 06-28-2018, 06:50 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
I called him and asked him if he could build you one and he said he can.... because he has done it before.
https://www.redlineg.com/services-gallery
DUB
blue427 (06-28-2018)
Old 06-28-2018, 07:20 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Since you already have a '72 gauge (that doesn't work), just buy an electric gauge (later C3 version) and sending unit, then swap over the dial face from the '72. The scaling is about right ('72 is 0-70 psi; later versions are 0-80 psi). I'm sure that's what the rebuilder would do.
Haggisbash (06-29-2018)
Old 06-29-2018, 07:05 PM
DUB
DUB's Avatar
No way in knowing what he would do unless a person calls and asks. I honestly do not think he is that sloppy.
DUB
Old 06-29-2018, 10:27 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Why not buy a 74 oil pressure gauge... https://willcoxcorvette.com/corvette-oil-gauge-74-74
To do this conversion you'd need to change the gauge housing on the back of the center dash cluster...https://willcoxcorvette.com/corvette...-used-original but the reproduction gauge will fit it perfectly. Then add a sending unit to the engine... Below I'll show you how to wire it. Here is how it installs... but if you get the reproduction gauge you'll not use the resistor, the resistance is built into the gauge on the reproduction gauges.
Then just run your wires... you'll need power, ground and ohms wires...
The following 2 users liked this post by Willcox Corvette:
C3 Stroker (06-30-2018), jim-81 (11-05-2018)
Old 06-30-2018, 12:07 AM
7T1vette
7T1vette's Avatar
Looks like a good way to go.....
Old 06-30-2018, 11:16 AM
MBrianB
MBrianB's Avatar
I'm glad I asked this question as it has been a learning experience.
I think I will go with the Willcox solution. Thanks for all the response.
Old 06-30-2018, 06:49 PM
DUB
DUB's Avatar
I did not know that Willcox sells them.
I was more concerned about the patina of your gauge face still being like that of the other gauegs so it would nto stand out or possibly have a different color or font size to it.
DUB
Willcox Corvette (08-26-2018)
Old 06-30-2018, 06:53 PM
MBrianB
MBrianB's Avatar
Thanks DUB. My gauges have all been refurbished by the PO so a new one will probably match. Also sending you an email re hood adjustment.
Old 08-24-2018, 04:21 PM
C369GS
C369GS's Avatar
How does this affect the other gauges? I'm planning to do this change to my '69 while installing a GM Performance crate engine. It looks like that housing is so different from the other years that all of the gauges would need to be replaced.
Old 08-24-2018, 04:48 PM
tpfarm
tpfarm's Avatar
I did the Wilcox conversion on my '73 and it worked out fine. Can't tell much difference in the patina from the other gauges . It would make a cleaner installation if you can mount the sender in the plug hole above the oil filter instead of around the distributor area it's kinda tight in that area. I could not get the plug out above the oil filter so had to mount the sender on top .
Old 08-25-2018, 12:45 AM
7T1vette
7T1vette's Avatar
'68-71 gauges used lettering/numbers that had a slightly greenish tint; "72 and later used white. The font and graphics were similar through 1976 (I believe). Main thing is to buy the gauge and the mating sensor from the same supplier. If you buy a 1975 gauge, also purchase a 1975 sensor so they will work properly together.
Old 08-26-2018, 10:10 AM
0Willcox Corvette
Former Vendor
Not so... If you change the gauge housing you'll be fine. The Battery, Clock, Fuel and temperature gauges all mount the same way and on a car with a mechanical oil pressure gauge there was a square hole in the housing...
The issue is the square hole for the oil pressure gauge.. I've never checked but you may be able to just drill the holes for the oil pressure gauge too.. So I'm looking at the pictures below and don't really see any reason you couldn't just drill the extra holes... I'll have to check this on Monday.
Willcox
Gauge housing 74-76
Gauge housing 68-71
Willcox
C369GS (08-26-2018)
Old 08-26-2018, 12:03 PM
C369GS
C369GS's Avatar
Willcox
Those pictures help tremendously. Thanks! The ones I was seeing when I searched for gauge housings on eBay looked completely different (6 equal holes).
Old 11-14-2018, 10:36 PM
Pmccooey
Support Corvetteforum!
Pmccooey's Avatar
Reading the diagram above in Wilcox post, what is the ohm wire going from the gauge to sender? Just a 14 or 16 gauge wire?
thanks
Old 11-15-2018, 08:45 AM
0Willcox Corvette
Former Vendor
thanks
Actually, it's 18 gauge wire from the sender to the dash.
.Willcox
Website https://willcoxcorvette.com/
Tech Page http://repairs.willcoxcorvette.com/
Please bump our sale threads if you get a chance..
Old 11-15-2018, 08:59 AM
Pmccooey
Pmccooey's Avatar
Thanks!! Looking to swap this out on my 69. Still haven’t decided if I’ll be doing stock gauges or updated ones but I like the idea of no longer have oil run through the interior!
To Electric Oil Pressure Gauge
Old 11-15-2018, 09:36 AM
0Willcox Corvette
Former Vendor
It's pretty easy to do as long as you have the right backing plate... I'm not sure if we have the face rivets on the website, but I have them... so you cut the old face loose on both gauges, then rivet your face on. Once you do this it's pretty simple. I'm also not sure if you can modify the existing backing plate... I've never tried it.
Willcox
Old 11-15-2018, 03:50 PM
zwede
zwede's Avatar
Won't look right on a 69. 68-71 have green numerals, 72-up are white so a 74 gauge will look off. And if you put a 69 face plate on a 74 gauge the reading will be wrong as the mechanical gauge was 0-70 PSI and electric 0-80 PSI.
Old 11-15-2018, 04:29 PM
Pmccooey
Pmccooey's Avatar
I know. I was thinking of some autometer gauges. Looking to see which models fit nicely enough that I dont have to hack everything up.
Quick Reply: Electric Oil Pressure Gauge
