shift interlock
Old 07-17-2018, 06:25 AM
arandy
Support Corvetteforum!
arandy's Avatar
St. Jude Donor '08
Default shift interlock
Does anyone have a part number for the shift interlock solenoid for a 1995 auto? Thanks.
Old 07-17-2018, 06:46 PM
WVZR-1
WVZR-1's Avatar
Received 2,263 Likes on 2,026 Posts
Isn't one available but through the years several methods of eliminating, creative fixes have surfaced. I've no 1st hand knowledge but but here's maybe some interesting reads. What situation do you have exactly? This will get you a bump to the top at least and maybe generate some interest.
https://www.corvetteforum.com/forums...-solenoid.html
https://www.corvetteforum.com/forums...-btsi-fix.html
Shifter with BTSI Solenoid is a GM# 12551499 (Hasn't been available for maybe 10+ years)
Old 07-18-2018, 11:41 AM
markKlein
markKlein's Avatar
Are you talking about the brake safety solenoid that keeps you from shifting out of PARK? There isn't a replacement, just remove it.
Old 07-19-2018, 07:02 AM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
This is what I did, and not surprisingly, everything has been fine since.
Old 07-19-2018, 08:29 AM
markKlein
markKlein's Avatar
Originally Posted by ihatebarkingdogs
What year does this "interlock" begin? Thanks in advance.
It's a common safety feature that I believe appears on all automatic C4s (as well as almost all other brands of autos). They are notorious for failing and making it difficult to shift out of PARK, especially when the car is cold.
Old 07-20-2018, 03:02 PM
WVZR-1
WVZR-1's Avatar
No, not that one. (The 4+3 has the theft interlock too. Must be in Reverse to get the key out).
There is a "must step on the brake to get it out of Park" by at least 1995, and that lock-out is the subject of this thread. I am curious to know which year this started. I judge Operations in NCRS, and would like to check this feature, if equipped.
'94 along with the 4L60e
IHBD (11-22-2018)
Old 07-21-2018, 07:47 AM
markKlein
markKlein's Avatar
The "must step on brake" feature is what I was referring to. I thought that my '85 had that feature, but a quick check of my old owners manual shows my memory was faulty. Thanks for the correction WVZR-1.
To shift interlock
Quick Reply: shift interlock
