62 rear axle stubborn wheel stud removal
Hello All,
I broke a rear axle wheel stud. This stubborn stud will not remove, I have tried penetrating oil and hitting it with a hammer (No Luck) I tried heating it up and hitting it with a hammer(still no luck). Do I need to pull the axle and have it pressed off? Never had one so stubborn.
Any advice will be greatly appreciated.
Thanks Jerry
Thanks Jerry
Jermo (10-21-2018)
Few blips with an air chisel should knock it out.
Jermo (10-21-2018)
Jermo (10-21-2018)
Jermo (10-21-2018)
I agree with the guys above, never use a hammer to drive out studs, use an air hammer instead. Or, you can do like I am, and replace the whole axle with new ones that have screw in studs.
Jermo (10-21-2018)
Jermo (10-21-2018)
Thank You All, I guess I'll be pulling the axle, might as well change out both seals while I have it apart
Received 3,443 Likes
Very, very good points. 1. Verify it's still true while it is still in the car. 2. If it is still true, remove and use a press to do the job properly. Studs should really never be done on-car for the reasons already stated. As an emergency repair for a beater, sure. But a classic with original parts? Nah.....
Yup, pulled the axle and the air chisel did the job, replaced the stud, put the axle back in all good to go
