Question for engine gurus
Old Jun 8, 2026 | 04:01 PM
20mercury's Avatar
20mercury
Default Question for engine gurus
Can I put these non vented valve covers on a 68+ sbc and drill vent holes in the rear for pcv/air filter ??? Or is an internal baffle needed? Or install as is? They certainly look good. Or is this a really dumb question lols!
Regrets?
Old Jun 8, 2026 | 04:20 PM
427Hotrod's Avatar
427Hotrod
2017 C2 of Year Finalist
First...are those bolt holes staggered or straight across from each other top/bottom? Hard to tell for sure in pics. Early ones are staggered and not likely to fit your heads.
They make some aftermarket ones with PCV and breather holes in the sides of them. Or they can be drilled. A baffle is always a good plan.
We did a 400" engine where we drilled the rear of the heads and made up a baffle arrangement and routed hoses to a remote breather can. Worked great.
You can also use an intake with a breather on the fill tube. Some breather tubes allow a PCV to be installed also....but it doesn't work too effectively if there's a breather cap two inches away from it.
JIM
Old Jun 8, 2026 | 07:29 PM
lars's Avatar
lars
I did a system very similar to Jim's when installing 1964 Valve covers on the 407 SBC that I built for my '64 - I wanted the engine to appear "vintage correct." I used a pair of the Steph's Manufacturing valve cover spacers (to clear the roller valve train) and installed the breather and PCV into the spacers. There is a baffle on the inside to prevent direct oil ingestion into the system. Works perfectly:
Lars
Old Jun 8, 2026 | 07:58 PM
20mercury's Avatar
20mercury
Default You guys are great as always! Thanks!
I think these are straight across and not staggered. I knew about the staggered vrs straight issue which is easily visible.
However for the breather hole question, I did not know.
So many thanks! You guys are great as always. Thanks for taking time to respond!
These are some cool elegant solutions
Old Yesterday | 09:50 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
To Question for engine gurus
