Sanden compressor question.
Old Jun 11, 2026 | 09:20 PM
7t9l82's Avatar
7t9l82
Default Sanden compressor question.
Has anyone changed their 79 or so A/C compressor to a sanden? What other changes and does it work well. I do have a full jug of r 12 so I could go back to stock. Id really like a conversion kit if possible.
Old Jun 11, 2026 | 10:04 PM
Piersonpie's Avatar
Piersonpie
Vintage Air kits use a Sanden 508 compressor. I’m sure you probably don’t want their full kit, but you can see what else they do to them to make it work better than stock.
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yes, many of us have. You'll need a set of mounting brackets. A new belt and some custom made hoses.
The Sanden takes 1/4 of the power to operate. Huge improvement. Huge.
If your going to run 134. A parallel flow condenser is also highly recommended.
Lots of air-con threads on here.
Old Yesterday | 09:57 AM
interpon's Avatar
interpon
looking forward to your swap! pretty sure you can run r12 as is with sanden.. when mine takes a dump i will try sanden r12.. be good to confirm this.. seems should be a compressor swap and that's it would be nice if existing did not put metal in system...
agree , man that r4 sucks power and cycling... but its cold! i also have several pounds r12
on my 79 manual there is no kick up for ac so i go from 900 rpm idle to 700..
Old Yesterday | 03:17 PM
7t9l82's Avatar
7t9l82
I'm having no luck finding parts like brackets etc and condenser. It appears a couple businesses have closed. Any thoughts?
Old Yesterday | 04:36 PM
interpon's Avatar
interpon
old posts but alan grove?
https://www.corvetteforum.com/forums...onversion.html
another
https://www.corvetteforum.com/forums...t-upgrade.html
another
https://www.corvetteforum.com/forums...g-bracket.html
Old Yesterday | 07:56 PM
7t9l82's Avatar
7t9l82
Classic Auto air Is a division of another company that closed classic.
All these threads are years old
. I think the brackets can be found. Worst case scenario, I suppose I could go to a serpentine system.
Old Today | 12:48 PM
wolfk's Avatar
wolfk
https://www.ebay.com/itm/25668710033...gaAqniEALw_wcB
To Sanden compressor question.
