My 1961 Complete Rewire in one thread
I'm starting a new thread on this wonderful adventure. Hopefully this will help other rookies who attempt this process. Note that this is part of a process to install a new dash, new windshield and completely renew the doors.
I bought what I thought was a complete Lectric Limited rewire set (not cheap) including their blue diagram. I also already had a color coded diagram from Classic Car Wiring. Interestingly neither of them show every electrical component - missing such items as the capacitor in the instrument cluster when the car has a radio. I also printed out Joe Fisher's nice pdf on 58-62 dash cluster removal and installation.
The wiring in my car was a mess. I've already found more the 20 crimp connectors with about 1/2 buried under tape and wires with the wrong color. No wonder it had intermittent starting and lighting problems. I even found a harness section laying right on the wiper cable - good thing they hardly ever get used.
Seemed simple enough. Take some notes and photos as I disassembled everything and then put the wiring back together with proper routing this time of the harnesses and wires.
I'll post about some of my experiences, pictures and diagrams in following comments.
Hang in there with me. And thanks to all the people that have helped along on the journey of fixing my blue and white '61.
Popular Reply
12-08-2015, 06:00 PM
After getting an great pdf emailed to me that had lots of pics things have gone much better. I'm thinking I really should have laid the entire car out in the other stall in my garage but this is working out. The complete kit didn't include wiring and sockets for the front signals and after a review with our club electrical guy decided to buy these new. Complete also doesn't include the turn signal wiring so I'm buying that as well since I found one bare but taped over wire there.
The pic is where I'm at right now for the interior harness. Wondering if the "battery" gauge wiring is on correctly?
Also missing from the complete set are some grounds. Haven't determined the complete list. If someone has good pics or documentation for the grounds I'd like to see them. My car is a 2x4 270HP (aluminum intake manifold) with a 4 speed manual.
It looks like you have the wiring correct on the battery gauge: red leads to the stud on the passenger side.
Regarding the grounds, I worked up a document today showing what I think has most of the grounding points. Can't guarantee that I hit them all! Hopefully, others will weigh in with anything I've missed and I can edit the document appropriately. The PDF file is attached.
I have also attached the document done when we rewired the car with the Lectric Limited Deluxe set for the '60 with manual trans. in case that's the one the other members above have requested.
Dave Z
First things that I found. A 100% set isn't 100%. There aren't any harnesses for the front parking/directional lights. Per LL website these aren't a standard socket as they are integral to entire assembly. They do have a repair kit which comes with a DIY "warning" or you need to buy an entire new RH and LH assembly.
The coil to ballast resistor isn't large enough to fit on the current incorrect coil or an 091 reproduction that I bought. LL said to bend it open but after trying to do this gently I'm going to opt for using my Dremel.
Received 1,901 Likes
Cool thread John.
I'm just about complete after installing the LL wire harness package into my '62.
I'm to the point that I need to convert the standard engine harness over to single point alternator, and integrate an ignition system.
I do have to say that the Lectric Limited has worked out very well for me.
I'll keep watching!
Pat
I'll keep watching!
Pat
Good Progress
Old Joe (11-01-2018)
Or, do CF members get a discount?
Wiring
I just finished rewiring my 59 with Lectric Limited. I might have purchased an incorrect loom. I had wires and plugs for electric windows, electric conv. top, electric fuel pump, speedometer, tach, a complicated starter switch and headlight switch assembly......and others. I worked it out but ended up with wire routes that I'll never use for this car. (electric speedometer, tack, speedo??) It can be done but wasn't easy. 59 navy
Great thread. I'm just about to start on my '58 which has the added complication of a NOM, and was wondering what was the PDF you have with the pictures, and whether it would help me?
If relevant, can you please provide a link or email it to me? I can PM you with my email address.
David
I know you can order the LL wiring harness through several of the vendors. My concern was that there were so many "supplemental" wires besides the main harness.
I contacted Lectric Limited and spoke with a representative there. He spend a good deal of time going over each and every item, paying particular attention to many of the items besides the main harness themselves.
In the end, I know I could have saved some money ordering through a vendor, but I felt like I received a lot of information talking directly with the rep from LL. So I just went ahead and ordered directly through them, and as I stated earlier, LL worked out well for me.
I did have one issue with the gauge lights not working. The fuse panel (for gauge lights) didn't have juice to it on either side. I called LL and the guy told me within a few seconds what the problem was. It was the headlight switch. Apparently the main fuse panel (for gauge lights) is fed through the headlight switch. Obviously the guy knew what he was talking about.
So if it anybody is undecided on which wiring to go with, I suggest you contact LL directly and speak with a rep there.
Pat
Pat
Here is my email : grinta@bluewin.ch
Thanks a lot
Ferry
Dave Z
The following 7 users liked this post by DZVette:
csherman (10-30-2018),
David Moroney (12-09-2015),
Loren Smith (09-05-2018),
olchev (12-10-2015),
Old Joe (11-01-2018),
and 2 others liked this post.
Pat
Pat
John
Dave Z
Dave Z
Have a good day
Ferry
Based on your post I did call LL direct today, didn't get warm fuzzy feeling I expected, I'll call my go to vender tomorrow, and see how that goes, but you are right, the packages don't include all, and I want to replace one for one, and I want to know I am getting them all. Chip
Damn....that's not right, but I'm with you. If you don't feel like you're getting good assistance, then I move on as well.
I wish I could have, would have remembered the guy's name, because he really was a tremendous help to me.
Shouldn't have to roll the dice though as to which rep you're going to get!
[QUOTE=DZVette;1591071510]John
Dave Z
Thanks Dave Z
Great documentation - clear photos and excellent colour post-editing. I'm sure this will be very helpful for my '58. I will crosscheck between the '60 wiring diagram, the '58 wiring diagram, your notes and my actual NOM/Bubba wiring and should be able to sort out 95% of any issues.
Cheers
David
Dave Z
Thanks Dave Z
Cheers
David
Nice job on the PDFs Dave. I wouldn't even start this job without the Dr. Rebuild color pictorial schematics. They have the GM wiring schematic errors corrected and the connections have been checked on real cars. One of my better investments on both the C1 and C2...
