Feed Grade Molasses for Rust Removal
A while back I started a thread on Evapo-Rust - http://forums.corvetteforum.com/c3-t...and-after.html. Although I was pleased with the results I searched for a cheaper alternative and found out about feed grade molasses. A gallon of Evapo-Rust is $20 at Tractor Supply vs. $8 for a gallon of molasses.
In a tub I mixed a 10:1 solution of water to molasses and I have to say I'm pretty happy with the results.
The control arm on the right is after being in the molasses/water solution for three days. I removed it, wire brushed it, and hosed it off.
Location: Where it's always hot as Hell-South Louisiana.
1 Post
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
What is the ph of said bath? Looks like an acid bath cleaning..... Just wondering how safe it is ? Maybe you could package the 10:1 solution and get rich ????
Think I may try this my ownself on a few parts.
feed grade molasses.....where do you buy that and what would you feed with it? iis it some sort of mixed up food prodcut for pigs?
Nice! Have a few questions.
Where do you buy feed grade molasses, Agway or similar? Does Tractor Supply have it? How well does the water and molasses mix; does it need to be hot? And finally, did you keep the control arm immersed or just baste it periodically?
http://www.tractorsupply.com/game-at...1-gal--2188545 and the part was submersed for the entire duration.
They really work on aluminum wheels.
Location: Las Vegas - Just stop perpetuating myths please.
Try vinegar?
Vinegar works good also and pretty cheap at Costco. Haven't tried it on large painted parts yet though. But it will destroy magnesium, i have proven that.
cardo0
cardo0
You could even bottle up that goop when done with it and resell as "Corvette Flavored Molasses"...
