L98 rebuild cost
$1600-$2000 is the range of some of the estimates I just got. Builder I used offered to install any new hi-performance parts I brought to the shop. I went with the lowest estimate and got pretty good service. Builder also pulled engine and installed rebuilt for an additional fee. PM me if you want more info.
I was quoted $1,600 for a stock rebuild, if I pulled the motor...WW
If you rebuild it yourself
http://www.summitracing.com/parts/SU...0/?image=large
Since we have 85's, we have forged pistons so I would reuse those if they are in good condition.
Shop around.....I found a short block with new TRW forged flattops, all rebuilt in the classifieds for 500 bucks. I took it apart after I noticed the pistons were 40 thousands in the hole, turned out it had a 307 crank in it. Had my original crank turned to fit for 75 bucks. Found some rebuilt same casting heads for 275 on Ebay, which smoked like a biatch, due to the fact that they left the o-rings off the top of the valve stems. Everything else was tight. Summit TPI cam, lifters, springs, 125 bucks. Timing chain set and gaskets...75 bucks. E bay injectors 125 bucks. Took awhile and was a hassle, but worth saving the money to me. You could find a deal on a low mileage or new assembled Gen 1 long block and just add your L98 components for under a grand I bet. Remember....red line is about 4500 rpm, so nothing fancy is required if you are on a budget.
i have ASM Runners, ported base, ported plenum, but I want to rebuild the motor over the winter and put in new heads/ cam but want to stay mild
I have the Summit G5000 TPI cam kit....they claim 30 HP in a 305 with a chip, which I think is BS, since the cam just has a slight lift and duration over the stock cam. I am running a stock intake and the stock chip. I have ported the plenum and cut the lid. I have underdrive pulleys and pulled the vanes on the air pump, EGR delete, thin head gaskets from TPIS, AFPR and 19# Ford yellow top injectors. Gutted cat and Monza tips. I am also running a airfoil (I know it's a waste of 35 bucks) and a KN filter. If I was to do it over, I would run a hotter cam, but I am unsure of the benefit due to the rev limitations of the stock intake. After all that, I doubt I have 30 HP over stock. But I do have a excellent running L98 that I hope will last a good long time, or at least until I build that Mini rammed AFR headed 383 out of my original motor. I have a good education on how to do it now that I have worked over the stock setup.
