Musty Smell coming from AC
Old 06-26-2007, 12:45 PM
tac4005
tac4005's Avatar
Default Musty Smell coming from AC
It's HOT here in Arizona and lately there is a musty smell coming from the AC, but not all the time. Since there is no cabin filter to replace I bought a aerosol for $8.99 to kill the odors. I used it per directions ( spray in fresh air vent under the hood at windshield and into vents in the cabin) , but the smell comes back. Looking for suggestions...
Old 06-26-2007, 12:52 PM
Blown 346
Blown 346's Avatar
If you use the Recirculation button all the time, that will only recirculate the air in the cabin and after time it will create a musty smell. Mold and what not can form from moisture that builds up in the ducting and vent system.
Old 06-26-2007, 01:04 PM
AU N EGL
AU N EGL's Avatar
You have mold groing in there. Need something to get the mold out and clean those ducts.
Old 06-26-2007, 01:17 PM
tac4005
tac4005's Avatar
I do use the fresh air intake as well, and the musty smell is still there. How would you suggest I physically clean the venting system?
Old 06-26-2007, 08:43 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres a well below the drivers side cowl. It has three udder type drains. If the drains clogg it can grow mold, slime, and the decaying crap in the well will stink. Check that area for nasty crap and clogged drains:
Clean out the well and see if that helps.
BC
Old 06-26-2007, 11:05 PM
99 vett babycar
99 vett babycar's Avatar
do a search for "udders"
Old 06-27-2007, 01:07 AM
Ryan's Daddy Dan-Na
Ryan's Daddy Dan-Na's Avatar
Default try this?
I know this may sound REEEAALLLY stupid but, for years I have had GM A/C's and usually I will turn off the A/C compressor about five minutes prior to my destination. This warms the A/C heat exchanger in your system and will also dry it out. I usually do that in my MOPAR company car and it works great, no musty smell EVER! If you try it let me know either way and good luck and happy trails!
Old 06-27-2007, 01:50 AM
white90conv
white90conv's Avatar
I sprayed pure isopropyl alcohol (rubbing alcohol) directly in the A/C intake. I removed the inlet screen so I could spray more directly. This has eliminated the smell in my car. I used the whole bottle, a pint I think.
To Musty Smell coming from AC
Quick Reply: Musty Smell coming from AC
