C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Motec M150 to Vette with factory BCM?
Old 01-03-2015, 01:05 PM
Tuomas FIN
Tuomas FIN's Avatar
We got custom TT setup with PTE6766's and DKT housings and 4"/3,5" exhaust almost ready.
Old 01-05-2015, 06:48 PM
Blackonblacksls
Blackonblacksls's Avatar
Looks a lot nicer than most of the block mounted stuff you see.
Badass for sure
Old 01-06-2015, 01:37 AM
ace32x
ace32x's Avatar
Subd for results. About to undergo getting the m150 set up on my z aswell. John Reed is going to be making the harness and getting it all squared away for it.
Old 01-06-2015, 12:21 PM
inspector12
inspector12's Avatar
So is this your custom built manifolds, but still utilizing the DKT housing? Or did you scrap this kit all together and start over? Looks good though.
Old 01-06-2015, 12:30 PM
Blackonblacksls
I can see dkt on one of the housings in the kit.
their housing seem like the best option for a big power turbo that can fit in tight locations
Old 01-06-2015, 12:45 PM
Tuomas FIN
Tuomas FIN's Avatar
Started over, kept charge pipes we modded and IC from DKT kit. Everything else we made and designed ourselves. No need scavenge pump anymore. DKT housings works perfect on these kind of setup and Devin gave a great deal of new bigger turbos. We made 4" down pipes and 3.5" axle back. complete system can build together on the floor, including exhaust before installation back to body. Needed small frame mods to do and frame rails will be inlet pipes, front mount filters inside the fascia. That's under work..
Old 01-06-2015, 12:46 PM
Tuomas FIN
Tuomas FIN's Avatar
Agree.
Old 01-06-2015, 05:43 PM
inspector12
In an PM I thought I rememberd Tuomas mentioning that he used a T4flange so thats why I questioned it as I too saw the DKT. But if it was a T4 just thought it could have been precisions regualar T4 housings etc... Good job so far Tuomas!
Old 01-06-2015, 08:01 PM
ProEFI
Supremacy 1 car at a time
Support Corvetteforum!
ProEFI's Avatar
I think there is a member looking for someone near DKT if you can help just look at the forced infection section!
Old 01-29-2015, 11:05 AM
Tuomas FIN
Tuomas FIN's Avatar
Wiring harness. Aiming to retain stock systems functionality with Motec M150 including ABS, Stability Control, Instrument Panel, Body Control module etc. ABS harness is originally integrated in Ecu harness, so it redone. Rear driveline harness was done also. Ecu loom itself includes +200 wires. +500 terminals in all.
Old 01-29-2015, 12:05 PM
inspector12
That's super nice!
Old 01-29-2015, 02:53 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Good lawd. Looks like someone did a good job though.
Old 02-13-2015, 02:36 AM
  #33
Tuomas FIN
Tuomas FIN's Avatar
Filter piping under work. Keeps OEM A/C.
Old 02-13-2015, 10:52 AM
  #34
inspector12
Lots a work but looking good!
Old 02-15-2015, 11:50 AM
  #35
NICK YOSKIN
NICK YOSKIN's Avatar
St. Jude Donor '08
Tom you crazy bastard!As always top notch!
Old 02-16-2015, 01:48 AM
  #36
Tuomas FIN
Tuomas FIN's Avatar
Thanks for support guys
Old 02-27-2015, 04:19 AM
  #37
Tuomas FIN
Tuomas FIN's Avatar
Step 2: front end
To Motec M150 to Vette with factory BCM?
Old 02-27-2015, 04:27 AM
  #38
Tuomas FIN
Tuomas FIN's Avatar
True street car needs A/C system, even here
Old 02-27-2015, 12:38 PM
  #39
inspector12
I like all the work looks!!!
Old 02-28-2015, 04:06 AM
  #40
Pekka_Perkeles
Pekka_Perkeles's Avatar
Indeed!
Just superb.
Motec is a brilliant choice for this car. And having it integrated with the stock PCM/gauges etc. is an achievement as well. Very, very good!
Quick Reply: Motec M150 to Vette with factory BCM?
