10 Tech Tips Every C6 Corvette Owner Should Know
By -
C6 Corvette
Like every other car out there, the C6 Corvette has some quirks that owners should know – especially if they do their own maintenance.
While most of us still consider it to be a modern machine in many regards, the fact of the matter is, the C6 Corvette has been out of production for well over a decade to this point, and the oldest model from that generation is nearly two decades old. As such, most C6 Corvette owners are now facing the reality of dealing with maintenance on a regular basis, as parts tend to wear out and need replacing over time – not to mention the cosmetic maintenance one typically has to perform as a vehicle ages.
Also like any other vehicle out there, the C6 Corvette has its unique quirks and features that owners tend to learn of throughout the course of, well, ownership, but there is a better way. The YouTube channel Toys4Life has churned out its fair share of helpful content pertaining to the C6, and now, it’s back with yet another compelling clip. This time, we’re taking a look at 10 things our host believes every C6 Corvette owner should know – some helpful advice, indeed.
10 Things Every C6 Corvette Owner Should Know
Running Hot
First up, our host points out that if the C6’s engine temperature reading seems a bit high this summer – particularly when idling in traffic or moving slowly – it could be perfectly normal. The fans will kick in when needed as coolant temps continue to rise – hitting 199 degrees, in fact. Fan speed also varies, and won’t reach 50 percent until temps are around 215 degrees, with 90 percent power at 225.
Melting Plug
Speaking of cooling systems, the plug that connects the fan assembly to the main wiring harness tends to melt, but it’s easy to check – at least, when the Corvette is up on a lift.
Dead Battery
If a C6 owner finds themselves with a dead battery, it can be difficult to, well, get inside to pop the hood, due to the electric doors. However, in the rear, there is a special key lock that allows one to open the hatch, after which you can pull a cable to open the driver’s side door.
Escape Plan
If one finds themselves in a slightly different scenario – getting stuck in their C6 Corvette when the battery dies or they’re in an accident – there’s also a lever located near the floor that mechanically opens the door, too.
Window Indexing
Sometimes, the windows in the C6 Corvette lose their ability to index, which means moving down and up slightly when the doors are opened and closed to create a tight seal. To reset this, one simply needs to get in the car, hit start (but don’t start the engine), raise the window, and continue to hold the button for three seconds, then repeat those steps.
Dead Fob
If one’s key fob dies, you can enter the vehicle via the hatch method previously mentioned, and then set it on the passenger seat or dash to start the car. There’s also a slot in the glove box that’s designed to detect the fob, even if its battery is dead.
Modes
Every time one starts their C6 Corvette, traction control and active handling are turned on, which is good to know if and when owners intend to take their cars to the track.
Scan Tool
Given the fact that the C6 was quite advanced for its time, a scan tool is a necessity. The C5 came with a decent self-diagnosis system, but that isn’t the case with the C6, meaning that a scan tool is the best way to diagnose issues for DYI’ers.
Weak/Dead Batteries
The C6 Corvette has a bit of a reputation for suffering from weak or dead batteries, but that’s just likely due to the fact that most tend to sit for a while, and are only driven short distances. Luckily, the solution for that is simple – a battery tender.
Check Engine Lights
When a check engine light comes on while one is driving their C6, there are certain instances when one will want to stop driving immediately – if the light is flashing, it can signal a misfire and fuel getting into the catalytic converters, for example. You’ll also want to check temperature, oil pressure, and battery voltage readings to ensure they’re all OK, too.
Join the Corvette Forums now!
Brett Foote has been covering the automotive industry for over five years and is a longtime contributor to Internet Brands’ Auto Group sites, including Chevrolet Forum, Rennlist, and Ford Truck Enthusiasts, among other popular sites.
He has been an automotive enthusiast since the day he came into this world and rode home from the hospital in a first-gen Mustang, and he's been wrenching on them nearly as long.
In addition to his expertise writing about cars, trucks, motorcycles, and every other type of automobile, Brett had spent several years running parts for local auto dealerships.
You can follow along with his builds and various automotive shenanigans on Instagram: @bfoote.
