Sponsored by: Innova
Old Mar 25, 2015, 01:48 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
C5 and general audio FAQ
Old May 15, 2010 | 02:40 PM
  #161
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
first off make a new post this doesnt belong in FAQ, forget your loc. tap the low level ouputs with rca plugs coming off the headunit before it goes to the processor. i have a hot to in the faq a few pages back
Old May 15, 2010 | 02:41 PM
  #162
markcz's Avatar
markcz
The signal at the normal speakers is missing the bass, it's not your converter. The only places to easily get low frequencies is line-level at the HU outputs going to the conditioner, or speaker-level at the door subs.
Old May 15, 2010 | 03:11 PM
  #163
jfruzna's Avatar
jfruzna
pentavolvo
can you please guide me to the right place. I just looked and could not find it. I know this is anoying but im going crazy trying to figure this out. Thank you
Old May 15, 2010 | 04:27 PM
  #164
jfruzna's Avatar
jfruzna
Thank you very much i found it. Sorry for posting in the wrong spot.
Old Feb 1, 2011 | 04:03 AM
  #165
momo20's Avatar
momo20
some parts of this section need to be updated..as there are some broken links and pics that dont work at all..maybe it just me..but tons and tons of good info!
Old Mar 30, 2011 | 02:52 PM
  #166
alan7407's Avatar
alan7407
Scott:
I am considering making my own modification to my C5 bezel, but I have a few questions. Since you're in the L.A. area, is there any chance I can meet you face to face, or you can give me a call @ (805) 587-6707
Old May 6, 2011 | 12:43 PM
  #167
LBCBEN's Avatar
LBCBEN
Hello I’m sure you posted this tutorial a long time ago but i just got me a C5 corvette and I have the exact same radio the alpine and I’m trying to install it to my C5 I have a few questions 1 I can’t seem to find the remote turn on wire on any of the C5 wire harnesses so maybe it’s a different color? Can you help me with that? And also there are 2 wire harnesses on the Delco stock radio and are next to each other if you add another stereo do theses wire harnesses just get eliminated? Because the wire harnesses adapter that I got doesn’t seem to support them?. Or do you hook up the remote on to the power antenna? + Blue/White to the Blue?
Old May 6, 2011 | 03:55 PM
  #168
markcz's Avatar
markcz
C5 schematics are HERE
If you're keeping the stock speaker setup, the HU 'remote turn on' lead needs to be connected to the dark green wire at pin 8 of C1. You also need to connect the speaker level HU outputs to the proper speaker feed/speaker return wires on C1/C2, and line-level signal needs to be connected to 'Front Audio Signal' and 'audio return-common' on C4. If you have an interface adapter it should take care of all that for you, except maybe for the remote wire to pin 8.
If you're replacing the oem speaker setup, all you'd need the new HU 'remote turn on' for is to power up the antenna module if you have a coupe.
Old Aug 28, 2011 | 11:55 PM
  #169
-Fidanza-'s Avatar
-Fidanza-
Has anyone found an Illumination wire for a c5 without dual zone climate control??
Old Aug 29, 2011 | 05:55 PM
  #170
markcz's Avatar
markcz
Assuming the BCM produces that signal regardless of the HVAC you have....
This Pic shows the wire on the HVAC plug for dual zone.
This Pic shows that the wire you're looking at is circuit 390.
This Pic shows that circuit 390 is on the BCM at pin B2 of connector C3 (the green one).
Old Aug 29, 2011 | 06:41 PM
  #171
-Fidanza-'s Avatar
-Fidanza-
Thanks, you have been a big help!
Old Nov 5, 2011 | 10:55 PM
  #172
AZ Roadrunner's Avatar
AZ Roadrunner
Default C5 stock head unit lighted buttons?
On a C5 stock head unit, is the <-SEEK-> button supposed to be lighted up? Mine isn't illuminated.
Old Nov 6, 2011 | 09:25 AM
  #173
markcz's Avatar
markcz
They are all supposed to have lights, that's not an uncommon problem
You can repair DIY with help from this thread, or I believe there are several places you can mail the radio to for them to fix it.
Old Mar 22, 2012 | 03:58 AM
  #174
CatCam's Avatar
CatCam
Originally Posted by mwortham
In my car (2004 Z06) fuse 22 only supplies power when the iginition switch is in the "Run" position. It does NOT supply power when the key is in the "ACC" position, which ruled out the possibility of using fuse 22 for me.
After much digging around in the passenger side footwell for this connector (and digging around on the forum) I discovered that it DOES NOT EXIST in 2004 year model cars (and possibly 2003?). So I was left looking for other sources for +12v switched acc power...
I saw jawzforlife's post and verified that the brown wire coming from the ignition switched IS in fact the right signal. However, I was hesitant to tap into this wire so I looked for another source. Here's what I came up with:
Look for a small bundle of wires under the steering column (you have to remove the interior panel that covers it first) - the colors should be grey, purple, pink, sea-green, and yellow. The yellow wire is switched +12v power:
I used a scotchlock connector to tap into it:
This wire will provide +12v power when the ignition is in the "ACC" and "RUN" positions.
Hopefully this will save some people time, as I spent hours trying to get all of this sorted.
- Mark
This is the info I need!! I will do the splice this weekend. I am currently tapped into the FUSE "22" slot but this is only hot when my key is in the "ON" position -- meaning my HVAC controls, yellow corner lights, etc are ON as well. This is some BIG battery drain if I'm sitting in a parking lot with the radio on! THANKS MARK!
Old Mar 22, 2012 | 05:21 PM
  #175
markcz's Avatar
markcz
I/P fuse #10 is hot in ACC
Old Mar 22, 2012 | 06:39 PM
  #176
CatCam's Avatar
CatCam
Markcz - is this in the passenger footwell panel or the one under the hood by the battery?
Old Mar 23, 2012 | 04:58 AM
  #177
markcz's Avatar
markcz
footwell
To C5 and general audio FAQ
Old Mar 23, 2012 | 07:59 AM
  #178
CatCam's Avatar
CatCam
Originally Posted by markcz
footwell
Yes, i see, it is the 25 AMP fuse, I will have to get a fuse tap thingy that fits over the switched leg of the 25 AMP fuse. I will run an inline 10 AMP fuse right after the tap. Thanks!!
Old Mar 24, 2012 | 12:00 AM
  #179
CatCam's Avatar
CatCam
MarkCz - I tried to put a fuse tap thing on the 25 AMP fuse and just couldn't get the fuse in with that tap on it. SOOOOO, I did the other method and tapped into the yellow wire -- THIS WAS SO EASY AND WORKS FANTASTIC!!!!
Thanks again to everyone who posted in this thread!!
Old Mar 24, 2012 | 09:58 AM
  #180
markcz's Avatar
markcz
Another option other than the add-a-circuit gizmo is a shove-in blade tap like this, just be sure to add an inline fuse on the wire. If you can't find one small enough for a mini-fuse just file down a full size tap.
Some other good options HERE
