Sponsored by: Innova
Big 3 pics
Old Mar 20, 2009 | 10:44 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
im sure for the right amount of money i can make it a kit
Old Mar 20, 2009 | 10:49 PM
jdmvette's Avatar
jdmvette
Night Owl for life
if you can get me a set of the 3 wires made up and ready to go, i'll take a set from ya.
let me know what it will run me.
Old Mar 20, 2009 | 11:10 PM
pentavolvo's Avatar
pentavolvo
haha that was half joking but let me figure out lengths or ill try and get DPG to measure it out and i have tons of wire i can cut and crimp and get you set up
i make no promises i am beyond swamped with school and installs right now
Old Mar 21, 2009 | 12:18 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Building a universal kit would tend to be a challange considerign types of connectors used, grounding/wire preferences.
Old Mar 21, 2009 | 12:56 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Has this subject been documented with pics, for the C6?
I've looked in the FAQ's and haven't been able to find it.
Any help as to the 'best' way to do this would be greatly appreciated. THNX.
Old Mar 21, 2009 | 12:57 AM
jdmvette's Avatar
jdmvette
Night Owl for life
no problem.
i'm planning on adding an amp and sub in the next month or so, so i figured it's best to get this done first.
let me know if you can hook a CF brotha up.
Old Mar 21, 2009 | 01:04 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i didn't know it was that complicated. i figured all i need is the 3 wires cut to the right length, (for a c5) with whatever connectors are needed to fit it to a stock alternator/battery.
hmmm...sounds like there could be a market for this. you should start building up sets and market them thru richard.
Old Apr 11, 2009 | 01:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
DPG
I hope you don't mind me adding this to your fantastic post!
I've been thinking about making this post for a while. Its raining and cold out and my ZO6 is beyond dead so, I'm bummed out.
If you improve the following MAJOR wiring paths, you will significantly improve the electrical system operation and efficiency!! Ive been studying this issue for a LONG TIME and here are my recommendation:
1- Follow this post and clean and tune up your IGNITION SWITCH. Its FREE and works very well!! Over a period of time the contacts inside the switch get burnt and some critical body control and PCM circuits receive less than actual battery voltage. Once you clean the ignition switch and improve the contact pressure on the switches, you will see a significant improvement in module functionality:
http://forums.corvetteforum.com/c5-t...ch-repair.html
2- Improve the battery to alternator circuit. The alternator charges the battery thru the starter solenoid. In that circuit there are in line fuseaible links and eyelet type connections that are exposed to heat, weather and corrosion. As time goes by, these connections become POOR and alternator performance suffers. Examine the attached GM Schematic and notice how the alternator connects to the battery and the fusible links on the starter solenoid for the alternator.
Heres a picture of the connections on the starter solenoid. They are the main cause for poor charging system performance:
Recommendation! Run a 4 - 8 gage wire from the POSITIVE battery terminal to the field terminal on the back of the alternator. Obtain a 60 amp fuse and fuse holder and install a fuse in that line near the battery to protect that hot wire from short circuits.
3- Better Chassis Ground at G-104/108. Chassis ground G-104/108 is a significant grounding point for numerous other chassis grounded circuits. ALL of the other chassis ground points enter the negative battery terminal through this wire.
Remove the negative battery terminal and remove the plastic/rubber cover from the battery terminal. You will see that the wire connections to the neg terminal are CRIMPED to the wire. This crimped connection frequently gets corroded/burnt/loose etc.. and causes poor performance. Remove the small negative ground wire from that connection and replace it with a 4 -8 gage wire. When you get the wire in the crimp connection, solder the connection. I use a giant soldering gun or a torch on low flame. Use lots of non acid flux for a good clean solder joint.
While your examining the battery terminals, inspect the POSITIVE BATTERY terminal wire crimped connections for proper conditions.
MAKE SURE THAT YOU PROPERLY ATTACH THE BATTERY TERMINALS TO THE BATTERY!! They need to be clean and tight. The GM torque spec for 97-2003 battery terminals is 11 ft/lbs.
If you follow the POSITIVE battery wires out of the crimped connection on the battery lead, you will see that it goes to TWO places:
- The Starter (main starter wire)
- The Engine Compartment Fuse Block, B+ terminal (main power for ALL the under-hood loads)
If you look at the pic below, you will see that the under hood fuse center has a B+ terminal on it that is where the battery cable connects to power the fuse block. You will also notice that theres a SECOND wire on that terminal. That wire is the B+ power wire for the Instrument Panel Fuse Block. NOTE! You will also note that in my pic, theres a "THIRD" connection. Thats my heated seat power line. You will NOT have this wire on yours
Some people have improved instrument panel circuit operation by incorporating that feed wire directly to the battery terminal; either in the crimp connection or if you have a side and top terminal on your battery, on one of those terminals.
General Chassis Grounds and circuit performance. Over the years, I have seen too many electrical problems to count. Many problems that I have seen can be contributed to poor chassis grounds. I have covered this in many electrical post but, make sure that you inspect and maintain your chassis grounds. Heres are some well documented examples of what hiding at your ground and grounding points!
THE GROUND SCHEMATIC!
The BIG THREE really does help. Get that engine and alternator better grounded to the CHASSIS!!!!
I hope this helps the BIG THREE get some more exposure and to help those of you who are experiencing POWER issue solve them. I will also copy this into my sticky (IMPORTANT ELECTRICAL INFORMATION (Long)
Bill Curlee
Old Apr 11, 2009 | 07:22 PM
Spying Beast's Avatar
Spying Beast
I'm not quite sure I understand how this mod will help with the alternator being able to generate more power as to supply the needs of a high powered after market audio system.
It makes sense in that you would get a better chassis ground, but that shouldn't help with the dimming of lights when the amps are at peak power.
Typically the use of a capacitor would correct, or at least decrees the amount of light dimming you would get, but that is done by storing & releasing power when needed, not by adding additional ground.
Can anyone explain this in lay terms?
Thanks,
Keith
Old Apr 11, 2009 | 07:56 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Keith
For all but the guys running 3 gigawatt amps and electric everything, the stock alternator will perform 100%.
When poor electrical connections and defective components cause low voltage and they start to see weird things happening to their C5,,,they think they need special high dollar stuff to fix the issues and they really don't.
If this post helps ONE person,,,to me, its well worth the time.
BC
Old Apr 11, 2009 | 08:40 PM
Spying Beast
AH, I see. Thanks!
Old Apr 12, 2009 | 01:12 AM
GKK's Avatar
GKK
Originally Posted by jdmvette
bumping up this old thread with a question.
are the big 3 wire upgrades strictly a DIY as far as making the wires themselves? or are there any premade kits that can be purchased already cut to the right lengths?
The Big 3 is a DIY project since not all people use the same exact areas for the grounds. It's easy to make the wires, just use at least 4 gauge wire from any audio electronics store and then buy the cable Lugs from any auto parts or audio store.
Solder the Lugs onto the 4 gauge wire and install.
Old Apr 12, 2009 | 01:59 AM
  #33
jdmvette's Avatar
jdmvette
Night Owl for life
^ i actually ended up going with 0 gauge for the alternator/battery and 2 gauge for both the grounds.
i also think an easy kit could be made for upgrading the wires exactly as shown in the original post. i think a kit like this would be great for 95% of most big3 upgrades.
Old Apr 12, 2009 | 02:27 AM
  #34
pentavolvo's Avatar
pentavolvo
Big 3 helps a ton the alternator is very capable, a capacitor is the last piece of garbage i would add to a stereo ever
Old Oct 19, 2009 | 06:24 PM
  #35
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
TTT to help distribute the BIG 3 electrical system improvements. They really do help if your running additional loads on your electrical system.
BC
Old Mar 8, 2010 | 01:45 PM
  #36
IRON MAIDEN's Avatar
IRON MAIDEN
Can you explain the Big Three. Or is this right?
1) Positive cable upgrade from Battery terminal to alternator.
2) Ground cable upgrade from engine block to chassis(frame)
3) Ground cable upgrade from Battery to chassis(frame)
Old Mar 8, 2010 | 01:54 PM
  #37
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Correct
To Big 3 pics
Old Mar 8, 2010 | 01:55 PM
  #38
IRON MAIDEN
Thanks Flyer. BTW, I sent you a message about something else. Not sure if you got it or not.
Old Mar 8, 2010 | 07:36 PM
  #39
jdmvette's Avatar
jdmvette
Night Owl for life
i got your PM.
pics of my big3 upgrade can be found here:
http://forums.corvetteforum.com/audi...-for-a-c5.html
Old May 26, 2011 | 08:53 AM
  #40
TheeMike's Avatar
TheeMike
When I ran my wire from the alternator back to the battery, I disconnected the one that runs from the starter to the alternator. Woudl that be a problem? I am running a 4 guage from the alternator to the battery. About 6 foot if i remember correctly.
