Sponsored by: Innova
<<< Custom Hand Made to order Sub Boxes >>>
Old Apr 20, 2010 | 08:11 PM
  #41
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Originally Posted by JMc
I think after reading this thread I'm close to pulling the trigger on a stealth enclosure for my '02 vert. But I need some help with selecting the correct sub or subs to go with it.
Like Jason mentioned above, I want clean, tight, musical bass. Not big, sloppy, splashy "how low can you go" bass.
So, one speaker or two? Also, do you make boxes that would fit two 8" subs and still leave room to mount my JL amp in the center recess? Or is that going to compromise the sound I'm looking for? TIA.
I think you would be happy with a single Elemental designs 11kv.2 sub in a stealth enclosure. I have made boxes for a dual eight setup, but not with an amp. It just takes up too much space in the center well to provide efficient airspace for the subs.
Old Apr 23, 2010 | 03:49 PM
  #42
jnjmarshall's Avatar
jnjmarshall
Default Image Dynamics 10" sub
I am looking at getting a stealth enclosure for my 2000 Corvette coupe. The sub I am looking at using is a single 10" Image Dynamics IDQ10D2v3. Does this sub work in a stealth box so I can use the OEM compartment cover on it without it "rubbing" and creating sound issues?
Old Apr 23, 2010 | 11:28 PM
  #43
NVTHIS's Avatar
NVTHIS
Yes, this sub will work in a stealth box with no problems. OEM compartment cover will fit and allow room for the subs excursion.
Old Apr 26, 2010 | 12:34 AM
  #44
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
thansk for the inpout Jason
Sorry i have been so busy and have not had time to be on here reading all of these in between the bezels and the couple hundred messages a day
Old Apr 26, 2010 | 09:15 AM
  #45
AVEYARDK's Avatar
AVEYARDK
Ported or not ported? Whats the diff. In sound? Good and bads of each?
Old Apr 26, 2010 | 12:05 PM
  #46
NVTHIS's Avatar
NVTHIS
No problem, Dennis! I figured you are busy, which is a good thing.
Ported boxes are usually used where space isn't a issue. They are usually bigger than the typically sealed enclosure. Sealed enclosures are used for tight, clean and accurate bass response, while ported boxes would be used for bass if you wanted to be heard a mile or so down the road,lol. Sealed boxes are more for SQ, while ported boxes are mainly for SPL. Due to the limited space that the c5 vettes have, it is hard to build a ported enclosure and still have room for the subs recommended airspace.
Old Apr 26, 2010 | 12:25 PM
  #47
AVEYARDK's Avatar
AVEYARDK
Got ya......what is the volume in a sealth box verses a hang over? Would 11kv.2 sound better in one over the other?
Old Apr 26, 2010 | 12:27 PM
  #48
AVEYARDK's Avatar
AVEYARDK
Originally Posted by c5 bearsfan
thansk for the inpout jason
sorry i have been so busy and have not had time to be on here reading all of these in between the bezels and the couple hundred messages a day
time to get a good sec. To answer the calls and messages.....lol
glad biz is booming for ya.
Old Apr 26, 2010 | 12:54 PM
  #49
0Double D Mods
Former Vendor
try me back
i was on the phone and didnt get your number
here is my cell as well
608 778 1851
yea i told the wife i need a couple "sexy"taries
Old Apr 26, 2010 | 01:08 PM
  #50
NVTHIS's Avatar
NVTHIS
Volume in a stealth box is around 0.83 cu ft. A hangover box generally has around 0.93. With the 11kv.2 being only 5" deep, I can decrease the stealth box height to accomodate it's recommended airspace. I think the hangover box will be too big for the 11kv.2 sub, that is unless you go with a dual 11kv.2 sub setup.
