Ditching the factory NAV system.
please forgive my lack of knowledge on this.
I have read a few of the stickies and I still have questions. If the year makes a difference, my C6 is a 2005 and does not have steering wheel controls.
How hard is it to remove the factory NAV system? Is there a video or step by step pictures anywhere?
If I buy an aftermarket radio from a supplier like Crutchfield, are the adapters all plug and play or is there splicing involved?
If I put in a used stock radio (there is a cheap 2006 one on Craigslist) would that be plug and play, and would the Bose amp still work?
Received 1,636 Likes
Replacing the stock head unit with an aftermarket unit is fairly simple. There is no splicing of wires. You just have to buy the correct wiring interface (Pac Audio RP5-GM11). The Pac Audio will also allow your new head unit to work with your existing Bose system. Here is a do-it-yourself thread created by the former forum audio guy with some step by step instructions.
https://www.corvetteforum.com/forums...is-to-diy.html
The only 2 things you need to install an aftermarket head unit,
1- Pac Audio RP5-GM11 wiring harness with steering wheel controls
2- Metra 95-3304 double din face plate
Also, I highly recommend that you consider adding a reverse camera also while you are replacing the head unit. I went with a Pyle camera off Amazon. Model #: Pyle PCNM38FRV. Cost was about $17
irfangnosis (05-05-2018)
I really do not want a touch screen.
over the weekend I picked up a stock CD player for $40.
I am going to search for a good thread with pics to ad an AUX input to the factory unit. I did this to the stock radio in my C5. i cant honestly say how it turned out as my C5 is still apart.
This is what I am going with for now.
I didn't find a thread to put a 3.5 mm jack in it like you can for the C5.
there looks to be adapter to do Bluetooth thru a phone but I am still not yet warm and fuzzy with that. only had a cell phone for a few months now and am not able to use it well.
