Sponsored by: Innova
C6 NAV Removal Question
Old Aug 22, 2018 | 02:34 PM
grady's Avatar
grady
Default C6 NAV Removal Question
When looking at the C6 HU NAV screen, in the back, lower left corner, there is a wire with a 90* bend with no plastic type connector on its end but looks as if it is just pushed into the back of the HU.
Does that wire simply pull straight out the back or is there some other way it disconnects?
Old Aug 22, 2018 | 06:24 PM
TorchRedFred's Avatar
TorchRedFred
Sounds like you might be referring to the FM antenna connection. If so, it just pulls out.
Old Aug 24, 2018 | 11:47 AM
grady's Avatar
grady
That's it. I just pulled it out. Sometimes I have a little fear in just pulling things first.
To C6 NAV Removal Question
