Converting Stock Seats
#61
The above is also the 2008 PCA policy. If you want harnesses, you must have seats originally designed for for harnesses. Modified stock seats are not allowed. The starter will also flag you if they see you enter the track with a harness and the stock belt system employed.
2007 was a test year, now in 2008 the PCAs are not letting ppl that have harness on stock seats drive. Must have a seat designed for the harness system.
If you have stock seats, you use the stock belts.
In descussion with several PCA Chief Inspectors, this is not a moot point. it is THEIR WAY or the HIGHWAY.
It is more then just modification stock seats with pass though for belts. Those stock seats are not designed to be used that way.
In many cases the stock harness may be safer then harness on stock seats.
#62
After reading the PCA regs on harnesses and race seats, I was sort of confused on the part regarding inatallation of the sub belt (5-point harness). It stated that the sub belt had to be installed according to the manufacturer's recommendations.
But it didn't really say if it was the seat makers or the belt makers recommendations. I assumed that there must be a hole in the seat for a sub belt, but what is a typical (or recommended) installation method for attaching that belt? Should it bolt to the floor or to a bracket on the seat itself?
PCA has a number of events at PIR in Portland OR that would be fun to do so I'll wind up installing race seats. Knowing up front what has to be done for a sub belt install would be a big help so I don't get bounced at tech.
#63
Sub belts though the hole(s) in the seat bottom and bolted to the frame of the car. Look at you harness manufactures recommended mounting instructions.
Read the seat manufactures instructions for install the seats, and read the harness manufactures instructions for the harnesses.
Both should be on line for the seats and harness.
I have several. PDF files by manufactures if needed.
#64
St. Jude Donor '05-'08
Finsihed the Install of my Kirkey Deluxe Race seats with Hardbarusa seat rails this this week.
To be honest I cant believe I waited this long. Everyone that has passed through the shop has sat in them and cannot believe how comfortable they are and how SAFE you feel compared to the stock seats.
I am moving seats up on my recommended list of RR mods.
Workin on the Placement is the hardest part of this install. I pulled the seat out probably 15 times and made adjustments. This picture is around 5 and it changed alot from this
#65
Just imagine how much more secure you'll feel going into turn 1 or 11 at the Glenn this year with those seats!This is what we're trying to get the drivers who go many track days to understand.
It will only improve your driving(no need to concentrate on staying put in the seat),be safer in general,make you look younger,thinner,more attractive and the chicks will dig them!Although your results may vary!
Dave D.
NASA Northeast Tech
Dave D.
NASA Northeast Tech
#66
Dave D.
NASA Northeast Tech
Dave D.
NASA Northeast Tech
#67
CF Senior Member
This looks well commented on but to add my two cents...I know several C6 racers that have modified their stock seats to use a harness. In fact, I have an appointment at a local upholstery shop to have slots put into my seat (they sew them up nicely). The harness belts come-through the seat-backs right at the seam (on the C6 seats). I'll put my Brey-Krause harness bar in a few days later.
#68
Might want to check with any sanctioning bodies where you will run beforehand. I have read where some bodies will not accept stock seats that have been modified like you are planning. Maybe not a big deal, but checking first might save some money and hassle.
#69
does a Sparco Evo 2plus fit in a C5 coupe?
I'm 6'4" tall, with tall torso, and have a harness going through the slot in the seat back of my C5. I'm really not comfortable with the idea that the shoulder belts could push down on me in case of a crash and crush my spine. So I need a seat with slots higher up in the seat back. I read about the Sparco Evo 2+, but haven't found a local dealer that has it in stock. Has anyone tried fitting the Evo 2+ in a C5 coupe?
Also, I have aa Autopower race bar with the shoulder belts attached to the lower tube. I'm thinking that's too low for my torso height. What would be a safe way to raise the belts up to shoulder level?
http://www.gforce.com/pdf/harnessinstall.pdf has a description and pictures of proper harness installation.
#70
#71
I agree ! This is something I have been working on . I think that novice and beginners need to first learn to drive on streets before going to R compound tires . Also if you are going to start modifying your cars you needed to think about the safety equipment too !
#74
Well, this caused quite a discussion. I just wanted to be able to convert my seats for my 6-8 HPDE's a year and a few lapping days.
If I choose to swap out the seats to fixed back racing seats for these weekends what seats do you recommend? I want a seat that will bolt on my mounting brackets(stock) if possible. Does anyone do that?
#75
#77
No - it is fixed. I am weary of slides. I want that seat 100% stable and slides seem to go against that train of thought. This setup is not moving which IMHO means my harnesses have less chance of sliding off my shoulders in an accident.
At the end of the day once you get the seat in the correct spot you are not moving it anyway. I spent a bunch of hours getting the seat exactly where I wanted it, but now it is all of 10 mins to take it out and another 5 mins to put the stock back in.
#79
I know I ran my first 6 months on stock tires before moving to a more aggressive tire. It was not a slick though that did not come for another year after that.
#80
Headers cost how much? Good seat and mount cost? How many can install headers at home? Few without a lift PITA. How many can install seat at home? Many it is easy and low risk of problems with slight mechanically skill and few very basic tools.
I'll take a Kirkey and someone can take the headers on similar cars. I bet I will be in front of the car with headers with similar driver. Same with brakes I didn't know what I was missing till I had them. If your not getting a deep snug seat it won't hold you either running hard with slicks!
