Cage Progress
Old Dec 11, 2011 | 10:29 AM
brkntrxn's Avatar
brkntrxn
Default Cage Progress
Several of us dropped off our C5Z06s with Genesis One in north Georgia following last weekends NASA Road Atlanta event. Mine is the first on the chopping block. I'll keep this thread updated with pics as BJ sends them to me.
Most of this is prep. He had to pull out my rollbar, cut the fiberglass in the door sills and then weld in the mounting plates.
Old Dec 11, 2011 | 10:30 AM
brkntrxn's Avatar
brkntrxn
Old Dec 11, 2011 | 10:53 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Can't wait for all of us to hit the track in PTA.
Old Dec 11, 2011 | 01:07 PM
sperkins's Avatar
sperkins
Looking good.
Make sure to reconnect the ground in this pic or you'll be chasing all sorts of electrical gremlins.
Originally Posted by brkntrxn
Old Dec 11, 2011 | 02:59 PM
travisnd's Avatar
travisnd
That was the ground that make Val's car be a PITA right? Have you guys cut out all the wires rear of there? Now that I installed the manual trunk pull I have no need for all of that wiring back there.
Old Dec 11, 2011 | 03:04 PM
drivinhard's Avatar
drivinhard
yeah and it's all just useless ground stuff (trunk release, gas door release, rear defrost, etc). still don't know why that affected val's
Old Dec 11, 2011 | 03:05 PM
drivinhard's Avatar
drivinhard
or each other
Old Dec 11, 2011 | 03:11 PM
Crepitus's Avatar
Crepitus
Nice fitup on the main hoop. Im thinkin this is gonna be a great thread.
Old Dec 11, 2011 | 03:21 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
I pulled that entire harness and never had any issues. FM.
Old Dec 11, 2011 | 03:22 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Originally Posted by drivinhard
or each other
I barely touched you.
Old Dec 11, 2011 | 04:01 PM
Paul Schmidt's Avatar
Paul Schmidt
I remember when my cage was being built, I couldn't wait for picture updates. What about the fuel tanks. How is your builder working around that?
Old Dec 11, 2011 | 04:23 PM
travisnd's Avatar
travisnd
So you just cut it out around the passenger side footwell? Sorry for the hijack Kevin
The tanks are out... if they were in the car you'd be seeing them through the hole in the rear "wall". For my setup I took the tanks out and took the roof off before taking it to my cage guy.
Old Dec 11, 2011 | 04:34 PM
Paul Schmidt
It so clear too. I need to open my eyes.
Old Dec 11, 2011 | 04:56 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Yup, all the way up to the computer in the footwell and never had a problem. Go figure.
Old Dec 11, 2011 | 05:29 PM
brkntrxn's Avatar
brkntrxn
No problem with the hijack, I know where you race. Besides, all good information.
I will be leaving the wiring harnesses as they are until after the 2012 season. I spent WAY too many years in the electronics field to even want to mess with it. FM stands for "effing majic" for a reason.
-Kevin
Old Dec 11, 2011 | 06:49 PM
GS023's Avatar
GS023
If you don't mind me asking, what will the cage cost?
Old Dec 11, 2011 | 07:04 PM
brkntrxn's Avatar
brkntrxn
Right around 3k. As with anything, it could have been cheaper if I had done more of the prep and it could have been more expense if I had opted for more bells and whistles.
To Cage Progress
Old Dec 11, 2011 | 08:29 PM
rmackintosh's Avatar
rmackintosh
You sure that the tank will fit back in the hole with the cage pad wrapped around the frame like that? We had a HECK OF A TIME getting my passenger tank back in and my pad had just a little welds at the corner...not a steel plate wrapped around it?
Old Dec 11, 2011 | 08:56 PM
GS023's Avatar
GS023
Not a bad price for a good cage. I wish there was someone close to me that did that type of work.
Old Dec 11, 2011 | 09:32 PM
gmccreary's Avatar
gmccreary
Red Z06. Sure that's not my car?
