Cage Progress
Old Dec 14, 2011 | 10:43 AM
  #41
sperkins's Avatar
sperkins
Originally Posted by GS023
What type of tubing are they using?
1.75 x .095 DOM
Old Dec 14, 2011 | 10:49 AM
  #42
travisnd's Avatar
travisnd
Originally Posted by sperkins
1.75 x .095 DOM
You guys went with the thinner stuff huh? I was going back and forth and elected the .120.
Old Dec 14, 2011 | 11:07 AM
  #43
sperkins's Avatar
sperkins
Mine is 1.20 as well, but only because I didn't know any better. At the time, my base weight was over 3200lbs so I had to go 1.20 per the rules. I didn't put two and two together and realize that stripping the car would put it under 3200lbs. We figure my cage is about 35lbs heavier than Mark's.
Old Dec 14, 2011 | 11:16 AM
  #44
drivinhard's Avatar
drivinhard
http://www.rorty-design.com/content/...._strength.htm
Old Dec 14, 2011 | 11:17 AM
  #45
GS023's Avatar
GS023
1.75 x .095 DOM
Thats what I plan to use. How much weight do you think a cage like yours adds to the total?
Old Dec 14, 2011 | 11:19 AM
  #46
travisnd's Avatar
travisnd
Yep... Carlos said about 30-35lbs as well. However, .120 tubing is exponentially stronger than .095.
I just didn't want some scenario in the future where I was going to sell the car to someone who was 100lbs who would need to ballast the car up over 3000lbs to run ST2 or something and have a non-legal car.
As it sits now my car is under 2900lbs even with the .120 tubing... could have easily done .095 as well.
EDIT - using that calculator Mark linked .120 is about 20% stronger than .095 based on "moment of inertia".
Old Dec 14, 2011 | 11:22 AM
  #47
drivinhard's Avatar
drivinhard
about 130 lbs. figure 70 ft of tubing. kevins a little more with the nascar bars on the pass side
  #48
brkntrxn's Avatar
brkntrxn
I am not sure because I already had an Autopower 4pt rollbar in the car and it was very heavy as well.
Old Dec 14, 2011 | 11:26 AM
  #49
brkntrxn's Avatar
brkntrxn
Originally Posted by drivinhard
I like seeing these guys that are getting faster adding all that lead where you don't want it
it took me a year to get my car to run faster than it did pre-cage
I assume you are talking about the NASCAR bars on the passenger side as well as the dash bar (edit: not footwell) and factory bar?
Show me a race where there was NO traffic and you ran FLAT out for 45 minutes and I will concede your point.
Old Dec 14, 2011 | 11:37 AM
  #50
travisnd's Avatar
travisnd
Footwell bar?
Old Dec 14, 2011 | 11:47 AM
  #51
sperkins's Avatar
sperkins
Footwell bar?
You know I've kicked around this idea for a few months, but I just don't know if our cars would really benefit from the footwell bars. Our feet/legs are already pretty well protected due to the frame design. It'd be a different story on a uni-body car. Thoughts?
Old Dec 14, 2011 | 11:49 AM
  #52
travisnd's Avatar
travisnd
I don't see any need for one, but Kevin mentioned it in the post above so I was questioning him.
I focused my cage design on fitting my butt in the car and being able to get in out. I don't need more crap around my legs if I can help it.
I decided to not get the bar that goes between the A-pillar and top NASCAR bar specifically because I couldn't get out of the car with it there.
Old Dec 14, 2011 | 12:22 PM
  #53
davidfarmer's Avatar
davidfarmer
moment-of-inertia is the measurement for bending strength, which is why it is the primary focus of that calculator. It increases by radius raised to the 4th power, so increasing overall diameter has a HUGE effect on stiffness.
However, compression or tensile strength are purely based on cross section, so the strength increase with just the square of the radius. In other words thicker tubing does get "stiffer" faster than it gets "stronger".
Old Dec 14, 2011 | 01:00 PM
  #54
varkwso's Avatar
varkwso
the 35 pounds in the cage is worth it.
Old Dec 14, 2011 | 01:22 PM
  #55
brkntrxn's Avatar
brkntrxn
I meant dash bar, not footwell bar.
Old Dec 14, 2011 | 06:37 PM
  #56
gmccreary's Avatar
gmccreary
I'm sure I'll get slower.
Old Dec 14, 2011 | 07:57 PM
  #57
apexman's Avatar
apexman
Looking good! Some great info here as I am getting my car ready for a cage soon. I am only 150 so I could use the larger tubing and added weight and safety I guess.
To Cage Progress
Old Dec 15, 2011 | 07:53 PM
  #58
brkntrxn's Avatar
brkntrxn
Getting close!!!
  #59
brkntrxn's Avatar
brkntrxn
Old Dec 16, 2011 | 01:10 AM
  #60
travisnd's Avatar
travisnd
Nice, but that dash bar makes my shins shiver
