Cage Progress
Old Dec 17, 2011 | 06:05 AM
  #81
varkwso's Avatar
varkwso
Originally Posted by sperkins
I'm going to protest if you beat me. 2 extra attachment points.
This from the "little engine that could"...
Old Dec 17, 2011 | 11:41 AM
  #82
fatbillybob's Avatar
fatbillybob
So lets say you are a chicken. If rules say you can use 1.75" x 095 wall, There is no problem with using 120 wall on critical areas like rollover hoop and doorbars and then 095 in other areas. You can have the best of both worlds.
Old Dec 17, 2011 | 12:07 PM
  #83
sperkins's Avatar
sperkins
It couldn't a couple of weeks ago.
Old Dec 17, 2011 | 01:44 PM
  #84
Z06Tracker's Avatar
Z06Tracker
When he says "next to the door", he means outside the door, and I added a sign that read "parting out, take what you want"!
Originally Posted by brkntrxn
Yes, I made sure to park my car on the lift and your car next to the door.
Old Dec 18, 2011 | 12:10 PM
  #85
gmccreary's Avatar
gmccreary
I'm sure it's probably picked clean by now.
Old Dec 18, 2011 | 03:44 PM
  #86
brkntrxn's Avatar
brkntrxn
You definitely need a new hazard switch, but I left those halfshafts and brake lines alone!!!
Old Dec 18, 2011 | 04:44 PM
  #87
sperkins's Avatar
sperkins
Old Dec 25, 2011 | 10:24 PM
  #88
brkntrxn's Avatar
brkntrxn
Well, I tried to save it. At least the blower motor is still good. Had it not been for my oldest daughter, I would have had to take off the intake. I could NOT get bottom AC line bolt and she was able to reach it and get it started.
After I cut my hand for the forty-eleventh time and hit my head on the cage, $h!t started flying and it flew about eight feet out of the car. My daughter got to watch me turn into the Tasmanian Devil.
Old Dec 25, 2011 | 10:31 PM
  #89
brkntrxn's Avatar
brkntrxn
The interior is coming together. I took the opportunity to reroute and clean up some of the wiring. No cutting, just rebundling and zip tie'ing. Not Mark/Scott/Brian worthy, but good enough for me.
Old Dec 25, 2011 | 10:34 PM
  #90
brkntrxn's Avatar
brkntrxn
What did you guys use to cover the holes in the firewall? Pop rivet in some sheet metal or something?
Old Dec 25, 2011 | 11:03 PM
  #91
davidfarmer's Avatar
davidfarmer
Silicone then rivet anything metal. The firewall is plastic or fiberglass, so use anything at least that flame resistant.
Old Dec 26, 2011 | 07:33 AM
  #92
travisnd's Avatar
travisnd
Nice work Kevin. What are the two switches for? I like the switches you picked vs. the plain metal toggle I used. I agree working on the car post cage is a PITA! I did all my parts removal and wire reorganization before the cage. Like you I just re-routed and labeled the wires vs. cutting anything major out.
I had no issues removing my HVAC box, but I followed the service manual instructions which tell you to remove the blower fan assembly first which gives you just enough room to get the box out. I had already removed all the lines in the engine bay when I had my intake manifold off, so getting the box the rest of the way out wasn't hard. I don't see how it could be done with the manifold still in place.
Here are the closeout panels I made for the firewall. I used textured ABS plastic and used rivets and a line of black RTV around the edge. Here's a picture, there are 3 covers in all, one is small and circular toward the bottom center of the picture.
EDIT: If you look at the bottom left corner of the largest panel you'll see I used a door plug to fill that hole. I ended up removing that plug when I installed my kill switch. I used it to run the wires through the firewall and I drilled one next to it for the fire suppression system line.
Old Dec 26, 2011 | 08:52 AM
  #93
drivinhard's Avatar
drivinhard
what's harder than that is the AIR pump bracket/bolt. but everything is out of my car and the intake has never been off
Old Dec 26, 2011 | 09:10 AM
  #94
brkntrxn's Avatar
brkntrxn
Thanks. The two switches are for my transponder and Cool Suit. Morris and I fab'ed up those panels when we still had the dashes and all. I have always had my transponder on a switch because I didn't want it killing the little battery. It also worked very well for when Morris borrowed the car and used another transponder.
BJ got Morris' unit out in one piece, I have pictures of it. However, his arms are smaller than mine and he told me I was going to have trouble with the bottom AC line bolt. Tiffany got it loose for me and then I could get my fingers on it. I followed BJ's instructions and cross-referenced them to one of your past posts. The blower motor was the first thing I pulled out. The problem was the dash bar from the cage. I just could not get enough clearance to come up and over it. I am certain it would have been easy to do pre-cage, but I didn't have time due to the family situation.
Thanks for the pics on the panels. I happen to have some of that ABS stuff left over from when I ordered the sheet for the switch panels.
-Kevin
Old Dec 27, 2011 | 12:11 AM
  #95
brkntrxn's Avatar
brkntrxn
Made a bit more progress tonight.
- finished the wire rebundling and probably used 5lbs of zip ties
- fabbed some panels for the holes in the firewall (ABS plastic with epoxy and rivets)
- stabilized the gauge pod
- tucked away the mirror wiring in the doors
- made some FANCY door handles
Old Dec 27, 2011 | 12:13 AM
  #96
brkntrxn's Avatar
brkntrxn
I am assuming the terminals on the master cutoff switch have to be covered. What's the best method? Electrical tape? Surely someone makes a cap for this.
Old Dec 27, 2011 | 12:18 AM
  #97
brkntrxn's Avatar
brkntrxn
I also worked on my seat mounts and brackets in an attempt to get the seat lower and provide more clearance to the bar that goes over the door. After TWO hours, I came to the conclusion that I am already as low as I am going to get using the Sparco base and brackets. I'll fabricate something when I have more time and just live with it for now.
Ordered a mirror and some padding today. Hopefully they will come in before I take the car to the shop for a prototype oil cooler.
-Kevin
To Cage Progress
Old Dec 27, 2011 | 06:20 AM
  #98
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Electrical tape.
Old Dec 27, 2011 | 06:51 AM
  #99
Brent Dalton's Avatar
Brent Dalton
Like Jason said, electrical tape works, but they do make a cap. Pegasus sells them.
Old Dec 27, 2011 | 07:36 AM
  #100
varkwso's Avatar
varkwso
Bet Brian has them, or wishes he does...
