[C2] Fuel/Lead Additive needed?
Old Apr 3, 2017 | 06:13 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I don't think there is much controversy over whether or not ZDDP oil is needed for our older, original cars. Its more like how much you spend on it...
Old Apr 4, 2017 | 08:57 AM
Vettegeezer's Avatar
Vettegeezer
Probably more important than TEL in fuel is absence of ethanol in fuel. I only use ethanol free 91 octane in my '67 with 300 hp engine.
Phil M.
Old Apr 4, 2017 | 09:08 AM
rfn026's Avatar
rfn026
I use ethanol-free fuel in all of my collector cars. I went through a series of fuel pumps and gas tanks on a number of my cars. I can't say it was the ethanol but I decided I had to change something.
Ethanol-free gas is really common here on the Gulf.
Richard Newton
Do You Really Need a Real Appraisal?
Old Apr 4, 2017 | 09:19 AM
phil2302's Avatar
phil2302
Richard Newton
Wish I could get non ethanol gas up here in NY.
I am convinced my boats 4 stroke Yamaha engines are going to blow up from the 10% ethanol gas I have to feed them.
Old Apr 4, 2017 | 10:40 AM
GTOguy's Avatar
GTOguy
Originally Posted by SDVette
You don't say where you are located.. but in California, the best gas we can buy is 91.
So I also run a bit of Octane Supreme 130, mixed to add 3-4 points of octane.
Otherwise I have to retard the timing by an unacceptable amount.
The plastic bottles you see at auto parts stores are garbage.
I concur. I use TEL/Octane Supreme 130 mixed with crap Cali alcohol-gas in my '65 GTO which will detonate like a bomb without it. It's the only real octane booster that actually works. My '61 Corvette with 11:1 and a 383 will actually run on 91 unleaded gasahol. Must be the chamber design. I wish we could get pure gas in CA, but we can not. No need for lead additive for valve seat recession.....unless you pull a heavy trailer 30,000 miles a year.
Old Apr 4, 2017 | 10:54 AM
66 Double B's Avatar
66 Double B
Default How About This Stuff?
Unleaded booster.
Old Apr 5, 2017 | 07:34 PM
rfn026's Avatar
rfn026
Phil 2302
What makes you think it's only 10%?
My son works for BMW and handles warranty issues. A gas check has become mandatory in most cases and he said he's found situations where the gas was almost 20% ethanol. In most cases the fuel appears to have come from one of the huge retail operations that has no refining capabilities.
He gives me h*ll for buying gas at Costco. Of course I don't listen to him.
Richard Newton
Old Apr 5, 2017 | 07:56 PM
phil2302's Avatar
phil2302
Phil 2302
Richard Newton
Richard,
Here on Long Island gas pumps offer regular 87, mid grade 89 and premium 91-93 fuel. Regardless of which grade choice you make the pump states the fuel will contain 10% ethanol. I imagine the actual ethanol content will vary on analysis but they are representing it as a 10% blend.
Also available here is E85 the 85% ethanol / 15% gasoline blend. (cat ****)
Wish we could get fuel without the ethanol but the NYS gov in all it wisdom has made sure that it is no longer available to us.
Phil
Old Apr 6, 2017 | 08:35 AM
Vettegeezer
Originally Posted by phil2302
Richard,
Phil
Phil,
Here in central NY I have at least a dozen stations within 1/2 hr. drive. I think there are a lot of stations offering no-lead because of the boating community (Finger Lakes), where I am located. Did you ever check with the marinas in your area, you may find it there, but be prepared to pay marina prices!
Phil M.
Old Apr 6, 2017 | 09:03 AM
phil2302's Avatar
phil2302
http://www.pure-gas.org/index.jsp?stateprov=NY
I see plenty available upstate but unfortunately not a single one on the Island, marina or otherwise. I had previously called Marinas that sell fuel down here but no one sells it.
Thought it was NYS ban but it must be a county level gov "idea".
I have been using it in the 66 without any ill effects for years but I really think it is harmful to my Yamaha outboard motors.
I smell a conspiracy
Old Apr 6, 2017 | 05:18 PM
rfn026's Avatar
rfn026
The sign out front may not be the actual refiner. But you already knew that.
Sunoco just made major deal with 7-Eleven
"After the sale, Sunoco said about 29 percent of its wholesale fuel business will be 7-Eleven outlets, 25 percent to Sunoco dealers, 13 percent to commercial fuel buyers and 31 percent to distributors of Sunoco and other branded fuels such as Chevron, Exxon, and Valero."
Richard Newton
