Burning up Points and Condensor
Old Jul 25, 2017 | 01:53 PM
Old Pervette's Avatar
Old Pervette
Default Burning up Points and Condensor
Need help troubleshooting ignition issues. Recently had Wilcox rebuild the distributor. I added a new radio suppression resistor to the stock position on the wire loom per original. Also found and added a "rebuilt" correct dated 515 Voltage regulator.
Since these changes, I have gone through three sets of points (each set lasted about 20 miles). I checked the coil (stock 202) and had 1.7 on primary and 11.3 on secondary. Checked ohms at ballast resistor and got no readings. (So how was the car running??)
I do not know if the issue is coincidental to recent additions or related to them. Any ideas are welcome.
Also, anyone know what the correct number for the ballast resistor was (D1110??) Application is early 1966 327.
Thanks//Mike
Old Jul 25, 2017 | 02:30 PM
65GGvert's Avatar
65GGvert
Never heard of a radio suppression resistor. Perhaps you meant noise suppression condensor or capacitor (for radio noise on AM).
If the ballast resistor is open, the car won't run when you release the key UNLESS it has been bypassed in some way. The wire to the coil should be on one end, and the wire to the ignition on the other. Depending on the application, it should read in the 1-2 ohm area with an ohmeter. IF it has been bypassed, that could explain burning up your points. With points used, it should always be in the line between the ignition and the coil pink wire.
Old Jul 25, 2017 | 03:03 PM
javac3's Avatar
javac3
7th Gear
Thanks//Mike
Connect a voltmeter to ground and to the + side of the ignition coil. Check the voltage at the coil with the ignition switch in the "on" position. You should read between 6 and 9 volts. Anything higher and you will burn out your points. If the reading is high replace your ballast resistor, it's a very inexpensive fix. D1110 is the correct resistor for your car.
Old Jul 25, 2017 | 03:25 PM
GTOguy's Avatar
GTOguy
This^^^^. The first thing to check. And very likely the issue.
Old Jul 25, 2017 | 03:50 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Define "got no reading" ?? 0 ohms?? infinite ohms?? Are you sure it's not bypassed from a prior electronic ignition installation?
Old Jul 25, 2017 | 04:23 PM
65GGvert's Avatar
65GGvert
If the reading is high in the on position, the ballast resistor isn't the problem. It isn't in the circuit if the voltage is high. You need to check to make sure the ballast resistor is wired in the circuit as I said in my earlier post. If the reading is zero volts in the on position it could be the ballast resistor open or a bad wire or connection.
Since the car runs, the ballast resistor is either good or bypassed. My guess is you're getting over 12v to the coil in both start and run due to incorrect wiring.
Old Jul 25, 2017 | 05:23 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Could be a bad voltage regulator.. What is the battery voltage when at high idle?
Old Jul 25, 2017 | 05:26 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
This has to be a mistake as we all know points never fail...
Seriously, if you have "no reading" across the ballast resistor its clearly wrong whether you mean infinity or a dead short.
As 65GGvert suggested retrace your wiring...
I don't know what you added into the wiring with a radio suppression resistor (no such thing), so remove it until you solve the running problem
Old Jul 25, 2017 | 06:56 PM
DansYellow66's Avatar
DansYellow66
Sounds like your ballast resister has been bypassed by some creative re-wiring. There's not a heck of a lot to trouble shoot on a ballast resister - either it has continuity and works or it doesn't have continuity and doesn't work (and the motor should die when the key is released). I'm sure there have been a few rare exceptions or malfunctioning resisters but not many. I would trace the circuits out in both directions from the resister per the factory wiring diagram.
Old Jul 26, 2017 | 09:16 AM
65tripleblack's Avatar
65tripleblack
Points shouldn't burn out in 20 miles with a bypassed ballast resistor. Has to be something else.
Old Jul 26, 2017 | 11:32 AM
plaidside's Avatar
plaidside
When you say the points burn out are the contacts pitted and is the end of the point arm blue?
With the key on and the points closed you should read approx. 3.6 amps and without a ballast it could read 7.0 amps.
Amperage is what does the damage to the points and coil not voltage.
Post a picture of the ballast wiring.
Obviously you have too much amperage across the points causing the failure.
One other possibility is the by pass circuit from the starter is staying energized by passing the resistor.
Where did you connect the "radio suppression resistor"? Can you post a picture?
Joe
Old Jul 26, 2017 | 11:35 AM
survivor66's Avatar
survivor66
A ballast resistor can only fail open, in which case the engine will not run with ignition on. If it is the proper resistor, look elsewhere. Something else is causing higher than normal voltage at the points. Also agree a bypassed resistor would not kill new points in 20 miles. If that were true, daily cranking of the starter would burn them out first.
Old Jul 26, 2017 | 06:29 PM
Old Pervette
Thanks for the responses guys. To answer a couple of your comments.
Had the car since 1983, NO mods to the original wiring harnesses. No bypass wire
Radio resistor (per NCRS) that mounts to coil bracket was one of the recent additions I mentioned (goes to + coil?)
Checking resistance on the ballast pinned the meter at 70 ohms on both hi/lo scale
Car starts up and runs fine but around 10-15 miles starts missing and breaking up. Came home on a deadstick from the hillside road one time. Put in new points and condensor and she ran fine....for a while. Repeat cycle.
Per JAVAC3, I will test + coil and ground with key on for voltage. Will advise
Old Jul 26, 2017 | 07:13 PM
65GGvert's Avatar
65GGvert
Your terminology is still confusing. There is no noise resistor but beyond that I also don't know what you mean by pegs at 70 ohms. If it's open the it should be Infinite and then you read the ohms of the resistor should be between 1 and 2 ohms. I think you need to get someone with electrical experience to check and see exactly what the situation is with your ballast resistor. However I doubt that's causing your points to burn up. If the resistor we're really open or very high ohms which is unlikely the car wouldn't run. You must be getting full alternator voltage while the car is running to the pink wire on the coil that runs to the ballast resistor. With the car running measure from ground to the pink wire on the coil with a voltmeter and report back what voltage are seeing.
Old Jul 26, 2017 | 09:38 PM
Randy G.'s Avatar
Randy G.
I was told that the metals used to make points nowadays does not hold up to the heat like the good old Standard Ignition stuff from 30-40 rears ago.
Old Jul 26, 2017 | 10:18 PM
W Guy's Avatar
W Guy
Are you disconnecting the wires from the ballast resistor before you check the ohms?
Verne
Old Jul 26, 2017 | 11:24 PM
Old Pervette
Yes Verne, I disconnected the pink wire on either end.
To Burning up Points and Condensor
Old Jul 27, 2017 | 07:04 AM
Frankie the Fink
Army
If you added your location to your profile there might be somebody that could come by and help you out.
Prob time you posted a picture of your points sitting in the distributor and their condition...
Old Jul 27, 2017 | 08:07 AM
DansYellow66
Now it's starting to sound like a bad coil to me.
Old Jul 27, 2017 | 08:31 AM
Frankie the Fink
Army
That's why I suggested the guy post his locale,
I have a stock coil and a NAPA coil and a physical inspection by another set of eyes or swapping in a spare part would prob solve the issue in 10 minutes. There are only a few things that can 'take out' points in 20 miles and most have to do with the high tension side of the ignition.
The OP has yet to answer Plaidside's question about the condition of the failed points which is important.
Done here.
