[C2] Lead additive
Old Apr 25, 2018 | 01:24 PM
  #41
Brian Kotula's Avatar
Brian Kotula
Originally Posted by MikeM
How does a lead additive affect this problem?
Raise's the boiling point of fuel.
Old Apr 25, 2018 | 01:43 PM
  #42
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Two additives I have proven to myself that work are Seafoam. I put that in a noisy lifter early LS motor and it was cured instantly. The second is an oil additive called Prolong. I know it works because in the winter at 30 below normal motors struggle to turn over, but with that slippery stuff in it, they spin over like it's summer. I was amazed at that stuff. I used it in my truck since it was new and it was running perfect at 325K KMS when I sold it. Never even opened the motor in that time.
Old Apr 25, 2018 | 04:16 PM
  #43
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Unless you remove the more volatile fuel components, those which boil off at a lower temperature, the "boiling point of fuel" (which is not one specific temperature) does not change no matter how much magic goop you add.
Old Apr 25, 2018 | 05:01 PM
  #44
Frankie the Fink's Avatar
Frankie the Fink
Army
In the interest of full disclosure I've run some Marvel Mystery Oil through some engines (twice I think) to clear us some gummed-up, sticky lifters due to poor maintenance by previous owners.
I don't add anything on a regular basis...
Old Apr 25, 2018 | 08:33 PM
  #45
GTOguy's Avatar
GTOguy
Come one, come all! Step right up and buy yourself your very own bottle of Fink's Wonder Tonic! It removes carbon. It cleans cylinders. It restores pep and vim and vigor to any motor. It re-vitalizes flat camshafts and lifters. It re-seals leaking gaskets. It flattens errant timing curves. It re-ignites Pertronic ignitions. Taken orally, it cures catarrh. It cures lumbago. It wrecks rheumatism. It consumes consumption. Yes, folks, for only $9.99, that's less than ten American dollars, you too can purchase a bottle of Fink's Wonder Tonic and be fully prepared for any future ills, automotive or biological!!
Old Apr 25, 2018 | 09:10 PM
  #46
Brian Kotula
By your definition Anti-freeze will not effect water in the radiator.
. Adding heavier weight hydrocarbons WILL raise the vapor point under pressure - usually enough to keep the fuel from vaporizing in the line or boiling off in the carburetor bowl while flowing.
Volatility is a measure of the gasoline’s tendency to vaporize under a given set of conditions. Reid Vapor Pressure (RVP) is a commonly used indicator of gasoline volatility. Boiling is a violent version of vaporizing. The higher the RVP, the greater the tendency to vaporize or vapor lock.
Among other places on the web - you will find a fairly good dissertation of the issue at => Evergreen Performance Systems, Inc. and Hydrogen Power Central | The true source for powering engines with Hydrogen - not "HHO"
Old Apr 25, 2018 | 10:37 PM
  #47
Powershift's Avatar
Powershift
And all along I thought it was called Casite's Motor Tuneup.
At least that was the name it had when I used it in 1964.
Larry
Old Apr 26, 2018 | 07:02 AM
  #48
Frankie the Fink
Army
You're gonna get me in even more trouble.....
Old Apr 26, 2018 | 07:42 AM
  #49
jim lockwood
As my sweet bride has said to me so many times when a discussion starts to bore her, "Yes, Dear. You are right Dear."
Old Apr 26, 2018 | 08:37 AM
  #50
phil2302's Avatar
phil2302
Scientific results are often polluted by researcher bias.
I do not use lead additive. Stopped 25-30 years ago on the advice of someone much more learned in automotive engineering than I.
I can only offer my limited personal experience as evidence of it being useless and that is two presently owned SBC 60's vintage V8's both still on standard bore and no changes to cylinder heads. valves or valve seats and > 150,000 miles with zero fuel related malfunctions using regular pump gas.
Old Apr 26, 2018 | 08:42 AM
  #51
65tripleblack's Avatar
65tripleblack
http://www.wildbillscorvette.com/octanesupreme01.htm
Old Apr 26, 2018 | 08:44 AM
  #52
Duck916's Avatar
Duck916
This same debate is going on over at the gymrat forum. Except they are talking about supplements.
The same unverified claims and, "it works for me" testimonials without any proof.
Old Apr 26, 2018 | 09:53 AM
  #53
Frankie the Fink
Army
I don't think I've ever heard those words in the same sentence with a term of endearment after 50 years with the same woman...
More like, "OK, you were right for once, goddammit"
Old Apr 26, 2018 | 10:45 AM
  #54
SWCDuke's Avatar
SWCDuke
Reid vapor pressure is measured at only one temperature - 100F. It's meaningful for cold starts and evaporative emissions considerations.
You need to look at the ENTIRE distillation curve and focus on the mass percent of components that are boiling at any given temperature. Ethanol boils at about 170F and considerably increases the percent of components boiling in the 140-150 degree range.
Adding a pint or quart of heavy hydrocarbons to 20 gallons of fuel will have little effect.
Duke
Old Apr 26, 2018 | 01:19 PM
  #55
Brian Kotula
Duke
Then why fuel percolation without lead and no fuel percolation with lead in same driving conditions! I don't advocate the use unless you have a problem but facts are facts, just like anti-freeze.
Old Apr 26, 2018 | 03:24 PM
  #56
MikeM's Avatar
MikeM
Larry
He gave you an answer in his response you just responded to.
Old Apr 26, 2018 | 03:39 PM
  #57
calwldlife's Avatar
calwldlife
St. Jude Donor '22
i just had my heads off a 70 350/250hp redone.
shop warned me that the exhaust seats are worn heavily
and expect to have them redone.
100k on motor, blown head gasket caused the
tear down. 194x160 valved heads.
so i am very interested in something for the exhaust valves.
hate to go lead but want to get as much time on valves as i can.
To Lead additive
Old Apr 26, 2018 | 04:24 PM
  #58
phil2302's Avatar
phil2302
Did the shop not mention stellite valves and seats?
Old Apr 26, 2018 | 04:38 PM
  #59
calwldlife's Avatar
calwldlife
St. Jude Donor '22
didn't have time or money to build the heads.
just wanted them checked and refreshed.
Old Apr 26, 2018 | 06:05 PM
  #60
MikeM's Avatar
MikeM
Valve seats wore out when leaded gas was used. Nothing new.
If the shop set your spring height correctly and ground the seats correctly, even if they were recessed some, I don't think you will notice anything wrong with your 250 hp engine. Just mo of course. Professional engine builders likely can prints pages where I am advising you wrongly.
