“Grease Caps” for King Pin
Old May 1, 2020 | 01:37 AM
Deuve399's Avatar
Deuve399
Default “Grease Caps” for King Pin
Hi Guys
I have been searching the C1/C2 Forum for King Pin “Grease Caps” and found last updated posts back in 2012.
My question is if any of you know a place to get the “Grease Caps” without having to buy a complete King Pin set ?
Rgds. Jan
Old May 1, 2020 | 07:46 AM
CaptainEgg's Avatar
CaptainEgg
Almost Retired
In a word No, how many do you need?
Old May 2, 2020 | 01:43 AM
Deuve399's Avatar
Deuve399
Just what I feared to hear 😳
During a brake tune up I found the top ones missing on both sides, so two will be needed.
Rgds. Jan
Old May 2, 2020 | 09:02 PM
JohnZ's Avatar
JohnZ
Try Kanter Auto Parts - they've manufactured the kingpin replacement kits for decades, and might sell you just the caps you need.
Old May 3, 2020 | 11:23 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
If I remember correctly, those caps were made of unobtainum. An alloy which is no longer in production.
Old May 3, 2020 | 11:57 AM
Plasticman's Avatar
Plasticman
The Kanter caps (if they would even sell them individually) fit terribly, and still needed epoxy for me to feel comfortable that they would not pop off during usage or greasing.
Old May 3, 2020 | 12:02 PM
GTOguy's Avatar
GTOguy
A photo would help. I was not aware of any grease 'caps', although I would assume they are on the ends of the king pin openings? I guess if they are not missing they go unnoticed.
Old May 3, 2020 | 01:04 PM
DZVette's Avatar
DZVette
Here's a shot from Tom Parsons' document (last page) on the complete rebuild of a C1 front suspension.
Note the part about only the top getting the cap.
Hope this helps.
Old May 3, 2020 | 03:03 PM
GTOguy's Avatar
GTOguy
Thanks for the photo. Personally, I would be inclined to use a cup plug (freeze plug) and be done with it. It wouldn't look 'correct', but it would seal it up just fine and stay put.
Old May 3, 2020 | 03:50 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Ya know.... when I changed the king pins on my '60 using NAPA kits, I think I remember correctly the kits came with simple expansion plugs.
Of course, I've rebooted since then.
Old May 3, 2020 | 04:14 PM
DZAUTO's Avatar
DZAUTO
Jim,
You are correct, each kit contains, or SHOULD contain, 2 expansion plugs per side (one top, one bottom) which are retained by snap rings. But the flimsy caps pictured above only goes on the top on each side.
Here is an expansion plug and snap ring, expansion plug (installed, but snap ring not installed), and cap.
To “Grease Caps” for King Pin
