Mid-year front end caster/camber shim size??
I want to get some shims to adjust the caster and camber on the front end of my '64.
What is the bolt size for the shims that are needed?
I want to have them available when I take the bolts out.
Tom Piper
Tom Piper
Received 1,859 Likes
Re: Mid-year front end caster/camber shim size?? (Tom Piper)
Upper control arm studs are 7/16"-20 UNF, and they're pressed-in studs with knurled shanks to hold them in the frame, not bolts; no need to remove them unless they're damaged. :thumbs:
