MY first vette (project)!!!
Old Apr 23, 2005 | 01:20 PM
  #41
saxmo's Avatar
saxmo
I guess with that statement... we have established that you are DEFINITELY full of it.
Old Apr 23, 2005 | 02:29 PM
  #42
Tall Boy's Avatar
Tall Boy
Welcome
If I did not drive a vette I would be driving a Camaro
Old Apr 23, 2005 | 11:41 PM
  #43
Glassbowtie77's Avatar
Glassbowtie77
Welcome and good luck with both projects.
Old Apr 23, 2005 | 11:53 PM
  #44
saxmo's Avatar
saxmo
Default Thanks For the Welcome!
maybe someone can give me some advice.. since there are some knowledgeable vette/camaro guys here.
I have a 1994 Z28/6 speed. I want to buy a crate LT1. I have found a source (Scottey Dickens) that sells different year and code (F, Y) LT1's. Which one would be the best to buy and put into this Z28? I noticed that the code Y 1994 LT1 is the most expensive one, but I'm willing to spend the extra few hundred if it is for a good cause. TIA
Dwayne
Old Apr 24, 2005 | 10:38 AM
  #45
JungleCat's Avatar
JungleCat
St. Jude Donor '05 thru '26
Dwayne
I'm no expert but I believe LT1s with the "F code" went into Camaros and Firebirds and had 2 bolt main blocks and cast iron heads. LT1s with the "Y code" went into Corvettes and had 4 bolt main blocks and aluminum heads. If I'm right, I think the difference in the two was about 30 or 40 HP. I hope this helps.
