Dangling Cable
Old Jan 25, 2006 | 09:57 PM
Jerry Curl's Avatar
Jerry Curl
The leak is about dead center under the hood. ANy ideas on what I should check first?
Old Jan 25, 2006 | 11:10 PM
Carl Granquist's Avatar
Carl Granquist
Default 70's Smell
I had the same thing happen to me when I brought home my '71 coupe. It smells different because it is different. Mine also has a slight oil leak from somewhere underneath, but two mechanics have told me that it's 35 years old and some of the seals are "weak" and not to worry. The gasoline smell had us concerned at first but I've gotten used to it. I just haven't found any leaks so I don't see anything that needs fixing or replacing.
Safety issues are a high priority and I don't pretend to know your situation. For me, though, I'm watching things but not worrying as much as I used to. By the way, this forum has a mechanic's checklist link that's great for the do-it-yourself owner who wants to tend to the routine maintenance. Very informative.
Old Jan 26, 2006 | 12:50 AM
John Ulrich's Avatar
John Ulrich
Scott/WagoneerJim,
Congradrats on the purchases
For piece of mind I'd make an appointment with a local "knowledgeable"
garage for a look see by experienced eyes.
A fuel leak and spark will lead to a burned vette. My buddy had his original Greenwood Wagon Vette catch fire .....twice. The second time finished it off!
http://www.sheldonaubut.com/vettewagon/adventure.htm
Good luck,
JU
Old Jan 26, 2006 | 10:29 AM
72LS1Vette's Avatar
72LS1Vette
If you aren't planning to tow a trailer with your Vette, trace the wires back from that connector and remove them. They are probably spliced into your brake and tail light wires. That dangling connector will corrode and could eventually cause problems with the tail lights and brake lights.
If you want to leave the connector, go to a RV store and get a cap for the connector to keep water out. Zip tie it up high so water won't splash on it.
BTW, a trailer hitch was an option on Corvettes - not sure which years it was offered. The license plate would fold down and the end of the receiver was behind it.
Rick B.
Old Jan 26, 2006 | 11:55 AM
SIXFOOTER's Avatar
SIXFOOTER
Not a leak, just marking its spot, like my Harley
Old Jan 26, 2006 | 12:25 PM
76stingracer's Avatar
76stingracer
Originally Posted by Jerry Curl
I thought of that, but then I tried to think of who would use a Vette to haul a trailer...
A lot of people use their vettes to pull a trailer. Most use the trailer for racing tires and supplies when we go racing.
Plus as said above, a hitch was an option.
Old Jan 26, 2006 | 12:50 PM
red topless gator's Avatar
red topless gator
YES!, Check the fittings on the fuel pump mine was leaking there...................LT
Old Jan 26, 2006 | 01:09 PM
Jerry Curl's Avatar
Jerry Curl
After further investigation, it appears its the power steering fluid leaking a little bit.
Old Jan 26, 2006 | 01:21 PM
NHvette's Avatar
NHvette
.... like 98.9% of all C3s. ... seriously
If you have the receiver behind the plate .. cool ... thinking of doing this
myself someday.
Old Jan 26, 2006 | 01:38 PM
wcsinx's Avatar
wcsinx
That's not a leak. It's a feature. It's how these cars cycle out the old fluid.
Old Jan 26, 2006 | 01:39 PM
wcsinx's Avatar
wcsinx
350ci small block and 3.70 rear will tow pretty well.
Old Jan 26, 2006 | 08:48 PM
1981 corvette's Avatar
1981 corvette
When I go in to the garage I smell gas too, on our 81, just found out it was leaking at the elbow fitting on the fuel pump.....
Good Luck,
Hans
Old Jan 27, 2006 | 12:34 AM
  #33
MoneyPit's Avatar
MoneyPit
Default Look out Barret J
WOW!!!!!!! you may have the next 300K car The trailer package was first offered in 1977 as RPO ZN1. I would have thought that it was the old ZO7 (off road suspension and brake package) It could have possibly shown on up in a late 1976 production I suppose. However, in 1977 the ZN1 option was the rarest production option (289 units). Therefore, by the twisted logic of some of the purchases at BJ, it would be more desirable to those damn yahoos at BJ There were more pace cars built in 78 than your car, and more L-82's built in 77 than your car. So hitch'em up and keep on truckin good buddy.
Old Jan 27, 2006 | 09:41 AM
  #34
Jerry Curl's Avatar
Jerry Curl
Assuming this trailer cable is a factory installed option, wouldnt there be a hitch somewhere?
The rear bumper was replaced on this car (the top was melted somehow when the guy had the car repainted about 5 years ago), so I dont know if any signs of a hitch would be obvious anymore.
Old Jan 27, 2006 | 09:48 AM
  #35
Hvymtlc5's Avatar
Hvymtlc5
I towed a ski boat with mine....I know it is violation of many's Vette protocal........but it's just a car.
Old Jan 27, 2006 | 09:53 AM
  #36
vettehead69's Avatar
vettehead69
2nd Gear
Stanky fingers, leaky seals and cycling fluids. Now this is the forum I was looking for!
That is definitely a trailer light plug hanging from your bumper. Or a fuse for the Vette-bomb?
Old Jan 27, 2006 | 09:59 AM
  #37
Jerry Curl's Avatar
Jerry Curl
You might think so after reading this thread. These guys have me scared Im going to explode when I turn the lights on in the garage.
To Dangling Cable
Old Jan 27, 2006 | 10:45 AM
  #38
Kilroy1024's Avatar
Kilroy1024
The rubber fuel line exits the tank at the top and runs over to the right side of the car where it joins into a steel line that takes it to the front of the car. I had a crack in the rubber line where it joins the steel line.
The fuel leaked out and dripped down onto the muffler where it quickly evaporated. I sould smell the fuel, but it didn't leave a stain on the floor. That is, until the drip got bigger.
It might be worth checking. Take a look above the right muffler.
It was a pain in the *** to fix. I was able to get my hand up there, cut off an inch of fuel line, and reconnect it.
Old Jan 27, 2006 | 10:54 AM
  #39
Jerry Curl's Avatar
Jerry Curl
The problem is, I dont have a lift.
These damn car sit way too low to the ground.
Im guessing based on these posts, its got to be that rubber hose or possibly that filter under the washer fluid tank. I dont get a gas smell when driving, and sticking my face in the engine bay doesnt yield a particularly powerful smell either, but I do smell it a little. Of course, I did have the garage door open when I was looking under there.
Old Jan 27, 2006 | 12:44 PM
  #40
desi's Avatar
desi
I noticed if you over fill the tank , the gas will leak. I leave about 2-3 from the lip.
