Dangling Cable
Old Jan 27, 2006 | 03:08 PM
  #41
Jerry Curl's Avatar
Jerry Curl
Well, I did top it off when I filled it up. It was on E and the pump shut off after about $25 bucks. So I gave it another squeeze or 2.
Old Jan 27, 2006 | 03:13 PM
  #42
wcsinx's Avatar
wcsinx
Originally Posted by Jerry Curl
The problem is, I dont have a lift.
Jackstands ... 4 of 'em ... don't need not steenkin' lift, mang.
Old Jan 27, 2006 | 09:11 PM
  #43
lucky76's Avatar
lucky76
Originally Posted by GATOR454
Is your Evaporative Vapor Canister (EVC = charcoal canister) hooked up properly. Maybe your just venting to the garage instead of the canister. Also, If your vent valve is defective you could have filled the tank too full and flooded the canister.
My 76 had this problem. The canister is located in the drivers side front fender under the master cylinder. Make sure the hoses are connected and a new filter in the bottom. Almost impossible to get to this thing.
