sidepipe covers
Old Mar 11, 2006 | 11:32 AM
cruz-n69's Avatar
cruz-n69
Default sidepipe covers
I just got a set of original 1969 GM sidepipe covers re-chromed. They look beautiful, the only problem is that I have no idea how to get the flat black paint (or whatever it is) to stick in the grooves on the covers. The original covers were flat black in the grooves and chrome on the "peaks", but now everything is chrome. Anybody ever have any experience with this and/or know how to get the original look back?
Thanx,
-BC
Old Mar 11, 2006 | 11:53 AM
Jims79's Avatar
Jims79
They make a primer just for chrome. Best bet is to ask a good body shop or paint store.
Old Mar 11, 2006 | 01:13 PM
Greg's Avatar
Greg
Just another Corvette guy
Hey cruz, What did it cost you to have them re-plated?
Old Mar 11, 2006 | 02:19 PM
cruz-n69's Avatar
cruz-n69
$1200
Old Mar 11, 2006 | 05:58 PM
tzeller's Avatar
tzeller
Cruz, I need to do the same thing to mine. I have been looking for someone in my area that can do that type of re-chroming. Mine are pitted and the chrome plating is peeling off.
Old Mar 11, 2006 | 07:35 PM
68/70Vette's Avatar
68/70Vette
Me too. I have a set that could use replating. I noticed that Cruz said he paid $1200. That's a lot of money, but I think the covers are cast aluminum and they have been chrome plated, so replating aluminum can be expensive. Is this correct? Can it be verified that the covers are cast aluminum? And also, who replated the covers?? Would like to know. Thanks
Old Mar 11, 2006 | 08:56 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If they're aluminum, why bother? Just polish and clearcoat.
Old Mar 11, 2006 | 09:30 PM
orourke's Avatar
orourke
This is what I did after I had my covers rechromed.
I cleaned the chrome with some surface cleaner to make sure there the surface was oil free.
Then I sprayed on two coats of Klean Strip " BULLDOG" adhesion promoter. It acts as a glue for surfaces that can't be sanded properly.It drys clear and can be bought in spray cans. Wal-Mart does sell it.
After the promoter is set,I sprayed on thin coats of Dupli Color "Cast Gray" over the complete finned area till covered.
Get a firm rubber or a foam sanding block and wrap a paper towel around it.Saturate the towel with lacquer thinner,then lightly run it over the tops of the fins to remove the paint. Don't soak the towel, it may drip into the valleys and distort the fresh paint. Just take your time, and change the towels after they load up with paint.
After the covers are dry ,clean them up with chrome polish and reinstall.
The paint in mine have never peeled or flaked off and I did mine years ago.
Old Mar 14, 2006 | 09:57 PM
cruz-n69's Avatar
cruz-n69
I believe they are cast aluminum and it was an expensive proposition. I had it done by an outfit in Fall River Mass named Nu-Chrome Corp. They do alot of antique and classic restoration and fabrication. They have a website, but the phone number is (508) 324-0002. Ask for Jack.
Old Mar 14, 2006 | 09:59 PM
cruz-n69's Avatar
cruz-n69
Thanks for the tip. I have another idea from another guy to use some pinstriping tape. I'm thinking I'll try that first and see how it looks and if it doesn't work out, I'll give the BULLDOG a shot.
Thanks much.
Old May 26, 2011 | 01:03 AM
Roma's Avatar
Roma
Thanks much.
Hi BC,
Iknow its an old Fred, but how was your result with the Tape ? My Covers are at rechromating and I will have the same problem in the near future.
Frank
Old May 26, 2011 | 09:10 AM
Alan 71's Avatar
Alan 71
Hi,
I believe the color in the grooves was a very dark gray with some texture and sparkle to it, not black. The gray phosphate spray can that Eastwood sells is very close. The visible part of the insulators was semi-flat black.
Regards,
Alan
Old May 26, 2011 | 11:10 AM
LS4 PILOT's Avatar
LS4 PILOT
Originally Posted by Alan 71
Hi,
Regards,
Alan
YES !!! you are correct !!.
The color is a ruff textured med GREY not BLACK . I have seen ones redun incorrectly in black stripes with rattle cans and it looks CHEESY& HORRIBLE and stands out like a sore thumb....
After spending all the effort to get them replated , don't do it half way, at least put the correct color finish back on.
Old May 26, 2011 | 01:14 PM
Roma's Avatar
Roma
Thanks Alan and LS4.
Can I apply gray phosphate spray direct on the Chrom or do I need some work to do first ?
Frank
Old May 26, 2011 | 01:45 PM
Corvette Kiwi's Avatar
Corvette Kiwi
My 1969 Corvette L71 is a factory side pipe car that at some point in its life was converted to a traditional rear exit exhaust setup (a previous owner probably wanted the car to be more quiet). I want to put the car back to the original side pipe configuration and I'm wondering what to do about the exhaust cut-out holes in the rear valance.
Could one of you post a photo (or PM me a photo) of what the rear valance looks like on an original side pipe car?
Old May 26, 2011 | 01:51 PM
fugawi's Avatar
fugawi
nu-chrome is good. had my front bumper,bumperettes,and grills done by them.
Old May 26, 2011 | 04:45 PM
Alan 71's Avatar
Alan 71
Hi John,
This is a 71 but has an original 69 side exhaust rear valance panel and quarter fillers. Notice the nice radius on the seam edges.
A pretty nice look!
Regards,
Alan
To sidepipe covers
Old May 26, 2011 | 08:17 PM
Roma's Avatar
Roma
Hi Alan,
did you build the "Quarterfiller" by yourself ?
Old May 26, 2011 | 08:29 PM
Alan 71's Avatar
Alan 71
Hi Frank,
Yes, I made a 'form' out cardboard and waxed paper. I layed up layers of mat and resin until I had the thickness of the quarter panel. It has a 1" wide lip that matches the 'lip' on the rear valance. There are 2 bolts on each side that hold the lips together and are also used to hold the quarter and valance in alighnment.
If you don't have a 69 valance let me know, and I'll send you a picture of the lip.
Regards,
Alan
Old May 26, 2011 | 11:06 PM
7T1vette's Avatar
7T1vette
There is a big difference in expansion rates of aluminum and chrome (and copper that is probably under the chrome). I'm wondering how well that chrome is going to hold up with all the heat/temp cycles those covers see. I hope they last and don't crack on you.
