astroventilation question
Old Jan 19, 2007 | 07:20 PM
RHD '68 L89's Avatar
RHD '68 L89
This is interesting....
My 68 vert Non A/C has a Flapper valve to seal the rear vent from returning air and water. No cable or vacuum actuation. I never saw any "filter" material when I had it apart. The flapper is on the cabin side of the assembly. There is also a hard rubber deflector in the rear deck vent to guide the rainwater to the drain holes.
Old Jan 19, 2007 | 08:22 PM
carl a's Avatar
carl a
Originally Posted by Jc3vette
My 73 with factory installed AC had the vents blocked by two metal plates. I obtained an assembly off a wrecked 68, it mounted with no problem. Connected into the vacuum hose for the heater. Works great. Closed for the Heater or Defroster, open for Vent and AC. No more tornado effect when the windows are down.
can you be a little more spacific on location and photo of part needed,,,very good idea ,i would like doing
Old Jan 20, 2007 | 12:28 AM
Ray Y's Avatar
Ray Y
I think my '70 vert is more like this set up. Fronts controlled by levers on console. Rears are manually actuated on the rear aft deck by a hand lever/bail mechanism that moves about 90 degrees. I've never looked it up in the books to see what is says.
Old Jan 20, 2007 | 12:34 AM
bwellisley's Avatar
bwellisley
i have a late 68, non a/c, with cable actuated doors
Old Jan 20, 2007 | 12:42 AM
RHD '68 L89
Yes, but is that the front kick panel vents which are cable operated? we are talking about the rear vent and the door in the rear of the cabin. If your rear astro door is cable operated it seems it is another variation. BTW my 68 is late production as well.
Old Jan 20, 2007 | 12:59 AM
bwellisley's Avatar
bwellisley
yes, the front are cable, but the rear seem to only be flaps...?
Old Jan 20, 2007 | 01:06 AM
RHD '68 L89
YEP,
same as mine, a flapper valve.
Old Jan 20, 2007 | 07:42 AM
vettepilot68's Avatar
vettepilot68
Originally Posted by 68/70Vette
My 68 Convertible (May15, 1968) is as described above; i.e. no astro-vent doors, just some thin rubber foam filter mounted in the two narrow rectangular openings between the rear deck vent bezels and the interior cabin.
Mine is April 26, 1968 and same setup...
