Turn Key.
Old Feb 8, 2007 | 03:01 PM
Durango_Boy's Avatar
Durango_Boy
Default Turn Key.
So I was out running the engine in my Vette the other day. Seeing as how it sits most of the time in the cold garage and hasn't moved since fall when it rolled in for brake work. That turned into 'Everything' work, and it's still down until I finish the interior.
Anyway, I start it maybe once every two weeks unless there is a specific reason to start it. I tend the battery once a week and have checked fluids and such but that's it.
I can reach down inside, standing beside the car, turn the key, and start the motor. After a few weeks it turns for a couple seconds...then fires. If it's been less than a week it fires right up like it was fuel injected.
How many of you can do that? Anyone have to pump and pump and wait and pump and wait...?
Old Feb 8, 2007 | 03:05 PM
another-user's Avatar
another-user
it comes and goes for me in the summer. some times i can hop right in and it fires up instantly, it doesnt even crank over once before its running. then theres other times im sitting there for 5 mins pumping, waiting, and cranking before it finaly runs.
it winter though... i can very rarly get it started after its sat for awhile without pouring gas down the carb. even then it takes awhile to finaly run.
the biggest shock for me was about 2 years ago. i had just put new plugs, battery, and starter in the car.
the car had sat all day long, i just put the clutch in, turned the key and she fired right up. didnt have to pump it or anything. then when i shut it off about 10 mins later, it actually stopped running as fast as it started. the car actually ran perfectly that day. then about 48hrs later i was ready to take a sledge hammer to it again.
Old Feb 8, 2007 | 03:13 PM
Durango_Boy
You may have a rich idle condition.
Old Feb 8, 2007 | 03:40 PM
JoeRags's Avatar
JoeRags
Pump it a few times and it fires right up.
My electric choke needs some adjusting. Sometimes when the car is hot, it has a very hard time running the first minute.
Megasquirt is on the list somewhere....
Old Feb 8, 2007 | 03:41 PM
Durango_Boy
If you're going EFI, Kalway is getting ready to do a sweet bolt on system that you should look into. It's pretty amazing.
http://www.rochesterproducts.com/
Old Feb 8, 2007 | 03:53 PM
another-user
oh i have lots of problems... but i hope this spring ill have an excellently running car.
i just picked up hte correct carb for my vette. when i get it im doing a complete tear down and rebuild. then when spring comes around im setting up the ignition system as directed in lars papers, and tuneing the carb the same way.
hopefully after all that ill have a good, dependable, and running car.
between that, the hurst competition plus shifter, and a real stereo, it wont be anything like what the car used to be.
Old Feb 8, 2007 | 04:04 PM
onaqwst's Avatar
onaqwst
you need to shield the distributor or something like that.... my dads 74 was like that.... when it ran, it was hard to restart so you would have to let it cool down a little.....
68 NJConv 454's Avatar
68 NJConv 454
Saw these carb looking EFI's in the January 07 issue of Hot Rod.
Wish their website was working so I could learn some more...although their prices look stiff. Padle shifts anyone? haha
http://www.retrotekspeed.com/
Old Feb 8, 2007 | 04:06 PM
Durango_Boy
I saw those...they look very interesting...thought they say their pricing will be low and competitive.
Old Feb 8, 2007 | 04:11 PM
mod81's Avatar
mod81
i voted for "fires after pumping" but it really depends, if she's been sitting for less than a day or 2 it'll start right up everytime, but after a winter in the garage she takes some pumps to get goin
Old Feb 8, 2007 | 04:18 PM
TexSon's Avatar
TexSon
When it hasn't run for awhile the bowls in the carb go dry and you have to refill them, thus the need to crank a bit for the pump to fill them. If mine hasn't run in 3 or 4 weeks I usually let it crank a few turns, stop. Pump the throttle a couple of times and then crank again and it normally fires right up. Most fuel injected cars take a few turns to start to ensure everything is working, especially oil pressure. Had an oil pressure senor go out on a '92 TBI system I put in a Jag and it was b!+ch to trouble shoot.
Old Feb 8, 2007 | 05:07 PM
JoeRags's Avatar
JoeRags
nah... my heart is set on megasquirt... I'm an electrical engineer, I want to build it, and have all the open-source tools at my hands. Plus, I want to fabricate my own intake setup.
Of course, I dont have the time to ever do this.
Old Feb 8, 2007 | 05:09 PM
JoeRags's Avatar
JoeRags
Thats exactly what my problem is... has to cool down to easily restart. What would shielding the distributor have to do with this? I've got an MSD Pro-Billet.
Old Feb 8, 2007 | 05:16 PM
Durango_Boy
I think it's your starter solenoid is getting too hot...or have you already checked into it?
Old Feb 8, 2007 | 05:45 PM
markdtn's Avatar
markdtn
Fuel injection. It starts within a second or so.
Old Feb 8, 2007 | 05:55 PM
JoeRags's Avatar
JoeRags
Well, the starter gets heat soaked, but thats a different issue. I'll get it running, but it idles very rough... seems like the choke is on, then it eases off and idles perfectly.
Old Feb 8, 2007 | 06:03 PM
marshrat99's Avatar
marshrat99
When the engine is cold, like overnight without running, I press the petal one time to the floor to set the choke and hi-idle.
To Turn Key.
Old Feb 8, 2007 | 06:26 PM
redvetracr's Avatar
redvetracr
[QUOTE=Durango_boy;1558872040] it's still down until I finish the interior.QUOTE]
don`t forget to "torque" your interior screws, I read somewhere that was very important.....
...redvetracr
Old Feb 8, 2007 | 06:27 PM
Twin_Turbo's Avatar
Twin_Turbo
Old Feb 8, 2007 | 07:02 PM
lars's Avatar
lars
Any car with a carburetor and an automatic choke has to be pumped at least once in order to allow the choke to close. Cars with torqued interior screws require less pumping. American cars driven in Europe will not start at all unless their owners buy cheap American beer at inflated European prices. (Hey Twin - how much are you paying for US Budweiser in Holland now?)
