C3 Subs
Old May 22, 2007 | 08:36 PM
  #41
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Originally Posted by phillymike
I'm planning on turning the jack storage area into an enclosure for a JL 8W7. I can't take up any of the rear area, since I need space for the soft top to fold down into.
Thats where I put my CD changer!
Old May 22, 2007 | 08:41 PM
  #42
celeryman22's Avatar
celeryman22
Here's a few pics of mine.
Old May 22, 2007 | 08:52 PM
  #43
markbett's Avatar
markbett
Originally Posted by mateo270
mark, do you have any pictures of your amp in the jack storage?
Give me a couple of days. I have the car stored up at my in-laws because I'm renovating my garage. It's tough to get up there. I'll send you a PM.
Old May 22, 2007 | 09:11 PM
  #44
7t2vette's Avatar
7t2vette
Way cool celeryman22!
Old May 22, 2007 | 09:27 PM
  #45
SILVERSIXX's Avatar
SILVERSIXX
Double 8's...pounds enough for me man.
Old May 22, 2007 | 09:28 PM
  #46
SILVERSIXX's Avatar
SILVERSIXX
Nice glass work man.
Old May 23, 2007 | 12:07 AM
  #47
CLINTR79's Avatar
CLINTR79
Originally Posted by MN80Vette
I like these the best! I want to put a pair of 8's in my '80. This box will be perfect. Do you have plans for this speaker box?
No i do not.A pair of 8's would need a smaller box,about .25 cubic feet each that one is .75
Old May 23, 2007 | 12:10 AM
  #48
CLINTR79's Avatar
CLINTR79
Originally Posted by Durango_boy
You won't want to aim your subs out like that. They're most effective when facing a surface like the rear bulkhead or the glass above. Facing them forward like that is killing most of the low frequencies.
That is true but i did it this way for looks and to use the least space.It sound really good for facing forward
Old May 23, 2007 | 07:20 AM
  #49
MN80Vette's Avatar
MN80Vette
The 8's I want to put in aren't subs. They are Pioneer or Bazooka coax 2-ways. However, now that you say that and I look at CLINTR79's box again, I think I'd tilt them up a bit to reduce the sound that goes into the carpeting.
That's the recommended volume for subs, right? How much volume should I have for 8" 2-ways?
Old May 23, 2007 | 07:24 AM
  #50
Durango_Boy's Avatar
Durango_Boy
That depends on the brand and model. Each speaker will have it's own recommended volume by the manufacturer.
It will usually say in the instructions of packaging found with new speakers. Used speakers is a different game as you have to look it up on the manufacturer's website.
Old May 23, 2007 | 07:38 AM
  #51
MN80Vette's Avatar
MN80Vette
I didn't know that. I haven't bought the speakers yet, so I will check the Pioneer and Bazooka web sites.
Thanks DB!
Old May 23, 2007 | 08:15 AM
  #52
Durango_Boy
Thanks DB!
No problem. It's just one more step that a lot of people miss and end up building a system that doesn't perform to it's potential.
I once bought a used system off of a kid for next to nothing because he bought all this high dollar equipment and wasn't happy with the sound. After buying it all for less than a tenth of what he paid, I found out most of his speakers were out of phase, he had the subs wired in series, and the box was waaaaay to big for the subs.
Point being, if his stereo install shop had done their jobs the kid would have been very happy with that system as the components were top notch.
Old May 23, 2007 | 09:16 AM
  #53
dewcustom's Avatar
dewcustom
here are 3 12"s and the t tops slide over the top for storage
Old May 23, 2007 | 10:39 AM
  #54
CLINTR79's Avatar
CLINTR79
Hey Dewcustom that looks great i bet it sounds and pounds good
Old May 23, 2007 | 03:45 PM
  #55
celeryman22
Thanks, it was pretty fun...
Old May 26, 2007 | 03:26 PM
  #56
1982CorvetteDude's Avatar
1982CorvetteDude
I kinda like what this guy did with his set-up, it looks like he made it for one 12" woofer and left spots for his amplifer.
Takes up most of the usuable room, but def looks good from the outside.
Old May 26, 2007 | 08:53 PM
  #57
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That looks sweet, but I don't like advertising my stereo equipment to every Tom, Dick and Harry that walks by.
To C3 Subs
Old Jul 5, 2007 | 05:07 PM
  #58
mateo270's Avatar
mateo270
Default 72 subs
Finally got my sub box built and installed. Sounds awesome. I went weith some 8" subs and a pair of 5x7's. Still have access to my storage doors, but thats about it. Thanks for all the ideas!
Old Jul 5, 2007 | 10:52 PM
  #59
Durango_Boy
Got any pictures of it? Good job on the project.
Old Jul 6, 2007 | 03:49 AM
  #60
rexx78's Avatar
rexx78
Originally Posted by Scott Marzahl
First I layered the wheel well and surrounding area with an aluminum foil covered insulation used for heater ducts that I found at Home depot before laying down the layers of resin soaked fiberglass mat. You could just used massive layers of tape and/or heavy duty aluminum foil but I chose the insulation material to add some height to the area to allow for the carpeting, and the foam insulation conformed to the rough textured areas on the body for a smoother backside finish. Once the resin dries, pry out the rough mold, trim to desired shape and glass in your shaped end pieces and add some more layers of fiberglass. Then you glue up your skeleton to hold the speaker ring. We are still playing with the angles for the speaker for these boxes.
I started making mine using cardboard templates. This sounds much easier. Are you going to have it sealed and bolted to the original mounts and to the front cover hanger?
