C3 Subs
Old May 17, 2007 | 11:26 AM
mateo270's Avatar
mateo270
Default C3 Subs
I am thinking about building a box for a pair of subs and some components to put in my '72, and was looking for some ideas. Any suggestions and pictures of what you guys have done would be great!!
Old May 17, 2007 | 11:33 AM
CLINTR79's Avatar
CLINTR79
Old May 17, 2007 | 11:34 AM
Scott Marzahl's Avatar
Scott Marzahl
I'm currently molding a set of boxes for 8" subs out of fiberglass that fit in the back corners and up over the wheel wells. Then the amp rack is mounted on the back wall and will mate up to the sub boxes. I can send you pics of the progress to date, it does take like 15 hours or more per box though by the time you lay the glass, stretch the polyester cloth over the formed shell and lay more glass etc.
Old May 17, 2007 | 11:47 AM
markbett's Avatar
markbett
I'd be interested in seeing those
Old May 17, 2007 | 12:28 PM
CLINTR79's Avatar
CLINTR79
Old May 17, 2007 | 01:24 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'd love to see those pics...I've been thinking of doing something similar, but with only one 8". I want to put a small storage compartment in the other side, and a set of components with 4" mids over the top of the wheel well. My sub only needs .31 ft3 of airspace.
Old May 17, 2007 | 01:26 PM
Scott Marzahl
If someone can post pics I'll take some tonight and email them to whoever can post.
Old May 17, 2007 | 01:28 PM
Durango_Boy's Avatar
Durango_Boy
You can post, just follow this link and viola.
http://photos.imageevent.com/durango...g%20Images.pdf
Old May 17, 2007 | 02:37 PM
77BuffaloVet's Avatar
77BuffaloVet
I have a 10" in a store bought box in the back of my '77. Leaves enough room to store the t-tops on the other side. With tweeters in the kick panels and 6x9 in the dash it sounds pretty good.
I really need to take some pictures someday, because I also have the aftermarket stereo and the amp mounted to a board that fits nicely along the top back of the rear storage compartment. I didn't have to cut out the original radio and I use a remote so I don't have to turn around, except to load cd's...
Good Luck!!!
Chris
Old May 17, 2007 | 03:04 PM
Scottys78's Avatar
Scottys78
CLINTR79 Wow that is a really clean install…
Did you do it your self?
Old May 18, 2007 | 11:35 AM
68RATVT's Avatar
68RATVT
My box takes up most of the back, enough room on top for the window only, t-tops are never on anyway. I run 2-10" bridged subs, the two mids and tweeters face forward,subs up. All are countersunk, the whole face comes off, gives it a smooth look. The amp and crossovers are mounted across the back and counter sunk also. She thumps pretty good...good luck..
the pix is kinda crappy,sorry..
Old May 18, 2007 | 12:50 PM
mod81's Avatar
mod81
not mine but sweet anyway!
Old May 18, 2007 | 02:24 PM
AZ78Vette's Avatar
AZ78Vette
I have a 12 inch kicker sub with 2 amps, a pair of 6x9s and a poineer deck. It takes up the entire back but looks cool i will take some pics tonight and post them up
Old May 18, 2007 | 03:01 PM
CCrane65's Avatar
CCrane65
I'm still trying to fit my 10" single sub box in my '72 and leave room for the TTops and the rear window tray to drop down.
Old May 18, 2007 | 04:42 PM
Scott Marzahl
Exactly why the reason we went with dual 8's. They allowed for storage and can still try to squeeze a rear window tray in. It won't be a factory tray but at least a "shelf" to store the window.
Old May 18, 2007 | 09:48 PM
CCrane65's Avatar
CCrane65
Ok, I turned the box sideways so the tallest part was against the wheelwell and I can fit the TTops in all the way over to the other side. I can't open the rear window tray with the TTops in there but that's ok if I need to I can take them out to get the tray down.
cc
Old May 19, 2007 | 12:09 AM
CLINTR79's Avatar
CLINTR79
YES THANKS
To C3 Subs
Old May 19, 2007 | 12:46 AM
onaqwst's Avatar
onaqwst
Old May 19, 2007 | 12:52 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Old May 19, 2007 | 08:05 PM
82Collectors's Avatar
82Collectors
