wiper switch console
Old May 19, 2007 | 05:22 PM
jnb5101's Avatar
jnb5101
Default wiper switch console
i'm puting my dash back together on my 70 vert.
the wiper switch bezel (not from my car, could be a later year) has three openings in the face. the top center is for the wiper switch. the other two are below and to each side, and are about 1/2" x 1".
what are these two openings for?
thanks, jeff
Old May 19, 2007 | 05:29 PM
...Roger...'s Avatar
...Roger...
seat belt warning and door ajar lens
edit-headlamp also
Old May 19, 2007 | 06:42 PM
7T1vette's Avatar
7T1vette
Unless I am missing something here, the two hole in the wiper control bezel are the openings for the A/C upper vents. You apparently bought the A/C version of that item...the non-A/C version has "C O R V E T T E" embossed on it where the vents go.
[The headlight warning and seat belt lamps are on the gauge bezel.]
Old May 19, 2007 | 10:29 PM
...Roger...
I thought he got his bezel terminology mixed up so I was going by the size of the holes.Could be wrong- sorry if I was.
Old May 21, 2007 | 08:23 AM
jnb5101's Avatar
jnb5101
thanks for the reply
the openings that i'm referring to are below the openings for the a/c vents. i think DW is on the right track. i think that the two openings are for indicator lights, but my wireing harness doesn't have any connections or light sockets that would insert in this area. that's why i thought that the bezel (ebay special) is from a different year, and my aim wouldn't show info on them.
edit-these openings are right below the fan speed and wiper 'push' lettering.
Old May 21, 2007 | 08:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Tell-tales for WIPER and WASHER.
Old May 21, 2007 | 02:24 PM
jnb5101's Avatar
jnb5101
thanks easy mike
is there a bulb(s) behind the lens or are they just plastic inserts? any idea where they can be gotten? i've checked the catalogues without any luck.
jeff
Old May 21, 2007 | 03:25 PM
7T1vette's Avatar
7T1vette
You might want to try ZIP Products [on-line]. I checked out the other aftermarket books and could not find them. Also, you might post a WTB request on the Forum parts section.
To wiper switch console
