Need Some Timely Input
Old Jul 7, 2007 | 09:47 PM
72LS1Vette's Avatar
72LS1Vette
Check the frame for rust, especially the differential crossmember. Feel inside the frame with a finger to see if there is a lot of loose scale inside the frame. Scale = metal+rust that isn't part of the frame anymore. Even if the frame isn't rusted through if there is heavy scale buildup (1/8" thick chunks or more) the frame is going to be much weaker than it was originally. Take a pointed hammer like a body hammer with you and tap along the differential crossmember and trailing arm pocket area. If you hear anything other than a metallic ring (like a thud) look out. You will either tap through a hole or metal that will soon become a hole.
Frames for chrome bumper cars are expensive and getting more expensive every day.
Rick B.
Old Jul 8, 2007 | 02:04 PM
Erics Quick71's Avatar
Erics Quick71
Had to delay pick up till Monday/Tuesdayy.
So have some time to look around at other questions I may have. BUT The mirror /birdcage thing is awesome input.
Anything else, lmk
Eric
