St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by Crazy81
Ever been laying under your car with your arm fully extended trying to reach the impossable bolt, then BAM, you just droped a 1/2" drive wratchet on your eye?
I saw the results of this very thing at the cruise in last year.
Originally Posted by 72LS1Vette
Never did that but when I was bolting up the tranny in my Alfa back in the 70's the wrench slipped and broke off half of one of my upper front teeth.
Rick B.
A guy I work with was changing the clutch in his work truck over the weekend. He was tightening the bolts on the bell housing when the wrench slipped. The open end hit his upper lip and split it in two. I mean laid it open where it needed stitches. Instead of going to the doctor to have it sewn up he sewed it up with needle and thread himself. It was the most ugly looking mess I ever saw. But it healed up and you can only see a small scar now.
I accused him of back talking his wife and her throwing a shoe at him. He said he only wished. He said he might have been able to block the shoe.
When I first strated working on cars all I could aford was one of those little Tiawan made socket sets. Still have the scars on my knuckles (al of them) to prove it. When I got my first crafsman set,, I was like " I wonder why the socket isn't flexing? shouldn't it be flexing about 3 inches?"
Once was working under a car, 5.0, changing the xsmission fluid, right under the fill hole w/pump, jammed in there, couldn't move, overfilled the hole one pump, got a mouth full of synthetic dextron III....
try pb blaster in the eye..... like a full stream.......
under the car ....reached for the can..... spray.....shyt....@#$%^%$#@#$%^
better yet
piece of wire from the mig fell off while welding a little piece and went through my shoe and stuck between 2 toes..... i think i hold the record for the quick take off shoe and sock performance
b
I think my experience can top that. I was under a car using a acetylene torch to burn of a piece of metal and a couple large blobs of molten steel bounced off of the frame and landed on my pants right by my zipper going clear through and landing on old Henry. I was out of commision for a couple of weeks.
I was doing some lost wax casting in high school when I burned some melted molding wax into the back of one of my fingers (the stuff melts at a much higher temperature than regular ol' candle wax). It took over a year for all of the wax to work out of the wound, allowing it to finally close permanently. Before that, it would heal over then crack back open a few days later, since it had actually gotten into the tissue under the skin level.
Know about that molten metal! I was removing exhaust pipes from the manifolds. Had the car up on Jackstands. Rounded off two of the exhaust nuts. Got the flame wrench out and figured if I got the nut glowing and cooled the stud with a damp cloth I could blow the nut right off the stud and save the stud. Great idea!! First one worked perfect! Second one blew right off the stud and dropped down the collar of my T-shirt. Reflexes! I jerked up and WHAM! hit my forehead on the frame, recoiled, burned my back, WHAM! hit my head on the frame, laid back down on the white hot nut, burned my back. Finally raised my back up and let it burn through the shirt and slid out from under the car. Had 4 DEEP burns well into the meat and 2 huge goose eggs on my forehead. SAVED THE STUD!!!!
