Autometer Gauges
Old Nov 9, 2007 | 10:31 PM
Recon12thman's Avatar
Recon12thman
Default Autometer Gauges
Im tooling around with the idea of pulling out the stock gauges and throwing in some autometer gauges. anyone have any tips and tricks or just plain advice when it comes to something like this
Old Nov 9, 2007 | 10:44 PM
78Vette-SA's Avatar
78Vette-SA
You don't say what year as they mount differently in early C3's vs. late.
Search back through the archives and you will find a number of posts on aftermarket gauges. One suggestion, is make sure you have a wiring diagram for your year as it will be helpful when you start cutting up the stock harness (is: Orange is 12v, pink is full, gray is dashlights, etc.).
I used the whiteface Phatom's and made my own Gauge mounting plates.
Old Nov 9, 2007 | 11:01 PM
Recon12thman
yea sorry its a 79 but i love how your gauges turned out. btw does anyone know if theres a special sensor to translate speedocable to a electrical signal for use with the electrical gauges
Old Nov 9, 2007 | 11:35 PM
rosslato's Avatar
rosslato
DAMN, that is just AWESOME!
Old Nov 9, 2007 | 11:50 PM
Crazy81's Avatar
Crazy81
The Auto Meter gauges come with the sending units. Installatin is pretty straight forward.
Old Nov 10, 2007 | 10:09 AM
EDDIEJ82's Avatar
EDDIEJ82
Mine can't compare to that and it is a work in progress but here is is with the Ultra Lites
Old Nov 10, 2007 | 11:37 AM
rosslato's Avatar
rosslato
i also went w/the ultra lites w/trim rings but didn't do the speedo n tach since they work fine
Old Nov 10, 2007 | 12:19 PM
TPI BOY's Avatar
TPI BOY
How are they held in place and do they fit
in the stock holes in the bezel I have a 75
Old Nov 10, 2007 | 02:46 PM
bluegtp's Avatar
bluegtp
here's mine....i'll get the dash in soon....waiting for headlight switch....i wanted more of a stock look....they are autometer designer series in black chrome......i made plates to go over the stock bezels and incorporated the blinkers and brights into the speedo/tach .......and there's a pic here of how i mounted mine....there's another little plastic piece that comes with the gauges that you can use to mount too.
Old Nov 10, 2007 | 07:13 PM
clive's Avatar
clive
It will look better once it is in and black.
Old Nov 10, 2007 | 07:33 PM
TPI BOY's Avatar
TPI BOY
Do they fit in the stock holes or do
you have to make them larger the autometer
ones
Old Nov 10, 2007 | 09:39 PM
1mpalss's Avatar
1mpalss
Default Try this site for '78 autometer gauge install
Try this site:
http://earchitect.50megs.com/corvette/gauge.htm
The install is somewhat easier in the older C3's, as the guages mount from the front side and are held in place from behind by Autometer's supplied mounting brackets. No need to cut the gauge holes, the 2 1/16" guages slide right in. Plumb the senders and wire them up.
I am running "full sweep" C2 guages (why couldn't they have called them C3's!), replacing my clock with an A/F guage. The full-sweep gas and voltmeter are kind of cool, compared to the standard (maybe 70 degree?) sweep electrical gauges. I'd post pics of my install if I had a digital camera and half a computer brain.
Old Nov 10, 2007 | 11:14 PM
clive's Avatar
clive
Mine fit easy. The tach and speed took some fab.
Old Nov 11, 2007 | 12:46 AM
rosslato's Avatar
rosslato
they're held in place by the retainer bracket like the one bluegtp has a pic of, except on mine u have to cut one side of the retainer down to match the angle of the trim ring
Old Nov 11, 2007 | 07:41 AM
clive's Avatar
clive
I didn't. Tight and flush fit.
I am not sure if I like the guage angles though on mine.
Old Nov 11, 2007 | 11:48 AM
panic's Avatar
panic
What is the size of the tach and rev counter gauges please??
Old Nov 11, 2007 | 11:53 AM
Bee Jay's Avatar
Bee Jay
Here is my 79 with Auto Meter. I wish I had gone with the carbon fiber with yellow hashes like Clive's. Let me know if you need the template.
Bee Jay
To Autometer Gauges
Old Nov 11, 2007 | 01:00 PM
TPI BOY's Avatar
TPI BOY
yes I would like to see the template
Old Nov 11, 2007 | 02:01 PM
myoriginal77's Avatar
myoriginal77
I'd like a template also please, frank@itpphoto.com
thanks
Old Nov 11, 2007 | 03:14 PM
TPI BOY's Avatar
TPI BOY
gtomlarson@hotmail.com
