I smell a re-stamp
Old Nov 14, 2007 | 05:26 PM
gccch's Avatar
gccch
Default I smell a re-stamp
What do you think? I see nothing resembling broach marks.
http://picasaweb.google.com/cartlin/...25284410870818
Besides this, it's an LT1 car and the only part of the car not in original paint is the hood.
Old Nov 14, 2007 | 05:31 PM
66L36Coupe's Avatar
66L36Coupe
Stamp looks too new and crisp - and the fresh metal surface looks uncharacteristic of an older pad with real patina.
Old Nov 14, 2007 | 06:34 PM
Alan 71's Avatar
Alan 71
ODD, but so difficult to make any kind of judgement from 1 picture.
Regards,
Alan
Old Nov 14, 2007 | 06:57 PM
dmayhew's Avatar
dmayhew
Default Re Stamp?
I agree with an earlier commet that 1 photo is not enough to tell.
I would say that the lack of broach marks in my openion only means
1 thing for a fact.
That is the block was decked.
You can deck a block and not go deep enough to remove stamping.
So no broach marks only proves that the broach marks are gone , anything else needs additional investigation.
David
Old Nov 14, 2007 | 08:11 PM
pwsusi's Avatar
pwsusi
Back up a level and there are more pics. These pictures also appear to be of an LT-1, not sure if it's the same car though...http://picasaweb.google.com/cartlin/Corvette
If these pictures are of the same car then they tell a different story. In these pics the block appears to have been decked, the VIN is not present and the suffix code is CGP (which I believe is from a 1971 350/330 Camaro)
http://www.chevy-camaro.com/chevy-ca...es.asp?group=8
Old Nov 14, 2007 | 09:09 PM
7T1vette's Avatar
7T1vette
dmayhew has a good observation.....but.....in the photo you can see raised metal around the stamped in numbers. If the block were decked AFTER the numbers were stamped, there would be no raised metal. Therefore, I think it's a re-stamp. BEWARE!!
Old Nov 14, 2007 | 09:11 PM
gccch's Avatar
gccch
That is a different car.
Old Nov 14, 2007 | 09:54 PM
dmayhew's Avatar
dmayhew
Default A closer look
After a closer look the suffix that I see is CKY
That is a correct LT-1 Suffix for a 1972.
1972 is the hardest to fake , look for a L in the vin.
If the original numbers were re stamped back on after decking then to me this is still a legitamate car.
Next task is to judge casting date of block against biuld date on motor , then build date of car.
Ask for previous owners to see if all answers match up.
David
David
Old Nov 14, 2007 | 10:13 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
WTH is this??????????????
wont let it pic. up
Old Nov 15, 2007 | 11:53 AM
gccch's Avatar
gccch
wont let it pic. up
Where did this link come from... it doesn't work for me... what are you talking about?
Old Nov 15, 2007 | 03:42 PM
GD70's Avatar
GD70
Here's the image lightened up. Hope this helps.
Glenn
Old Nov 15, 2007 | 03:49 PM
jim2527's Avatar
jim2527
I think this may be a different stamp. The block looks painted.
Old Nov 15, 2007 | 04:10 PM
GD70's Avatar
GD70
Looks the same to me. The rust pattern is exactly the same.
Old Nov 15, 2007 | 07:30 PM
gccch's Avatar
gccch
Glenn
That made a big difference. I'm not going to consider this car as it is being marketed as all original and I don't trust it. Either way it was a good exercise for me to validate what to look for...
Old Nov 15, 2007 | 09:09 PM
jim2527's Avatar
jim2527
My bad...i meant different from the stamp apd in the gallery. The gallery car ppears to have different engine....unless it was rebuilt.
Old Nov 16, 2007 | 08:17 AM
gccch's Avatar
gccch
Yes, the car in the gallery is different. It's the one I am hooked on, but it has other issues holding me back.
To I smell a re-stamp
