Custom Fiberglass Dash / Interior
Old Apr 2, 2008 | 01:45 PM
  #141
Jaybird907's Avatar
Jaybird907
Any Progress?
Old Apr 2, 2008 | 04:27 PM
  #142
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by onaqwst
you have a link to those gauges.... i'm looking to swap out to non-digitals
thanks
b
Nothing too esoteric about them - just Autometer Phantoms.
Old Apr 2, 2008 | 04:59 PM
  #143
jerrylee's Avatar
jerrylee
Hey guys what is the correct size gauges 4 our C-3's....2 n 1/16 or 2 n 5/8.........Thanx...Jerrylee///
Old Apr 3, 2008 | 12:28 AM
  #144
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
2 1/16".
Old Apr 24, 2008 | 06:57 PM
  #145
davidm_comp's Avatar
davidm_comp
Got a little progress on the dash.....
Picked up some Rage Extreme and mixed up a batch of milkshake, brushed it on the arm rest and center dash. Missed the sanding in greenstage, would have made it a lot easier if I did, but it still sands better than the duraglass. Gave everything a pretty quick and light sanding with 40 grit. Added two layers of re-enforcement to the underside. Might mix up another batch of milkshake tomorrow and hit it with some 80 grit in hopes of filling the heavy scratchs the 40 grits put down...
Old May 1, 2008 | 12:58 PM
  #146
davidm_comp
I added some glass to strengthen some weak points and then got started on finishing the cup holders. The bottles I ordered from US Composites fit in the holders good so I used it as a template for the bottom. Looks pretty good I think. So far I got two coats of glass on the drivers side and just put the first layer down on the passenger side. Next step is to get the two pieces I have been working on flow into eachother, then the rest of the dash needs to be fabbed up....
Old May 1, 2008 | 11:58 PM
  #147
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
while you are at it put an led in the bottom or side of the cup holder and run it to your interior lights. a clear water bottle looks really cool with an led under it. i was going to do this but decided not to have cup holders. nice work. keep the pics comming.
Old May 21, 2008 | 10:53 AM
  #148
Jaybird907's Avatar
Jaybird907
That looks great! So many ideas are running through my mind right now!
Old Jun 5, 2008 | 10:22 AM
  #149
davidm_comp
I have been neglecting the vette and her new interior pretty bad lately, but now that I see vettes crusin on the roads I got the itch and need to get the interior done a little more so I can start driving and going to some of the local car shows.......I have both cup holders done with 3 or 4 layers of glass on each. I taped the whole tranny tunnel with green painters tape, then sprayed the tape with contact adhesive and layed aluminum foil down over that, then I layed down two layers of chopmat. I don't have pics but I will try to get some tonight and get the tunnel mold trimmed up and looking somewhat pretty. After I get that done I will bond the center console down to the tunnel mold and bond the center section of the dash to the tunnel mold, this has a duel purpose, both to hide the edge of the carpet and to hold the dash in place. After that I need to get going on the left and right parts of the dash....
Old Jun 5, 2008 | 10:30 AM
  #150
davidm_comp
I still might put some in, I really wanted to have some cool lighting going on, but still be able to turn them off and look clean and classy.....
Old Jun 5, 2008 | 10:51 AM
  #151
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i am going to put all my leds on a separate switch or at least split them into groups. that way i can choose what areas to light and when. when doing your lighting, play with the locations and angles until you get the light you want without seeing the bulbs. leds are nice if not seen but if you can see the blub it can be blinding and mess up a nice effect. i cant wait to see more of your interior.
Old Jun 13, 2008 | 09:39 AM
  #152
davidm_comp
Got a few shots of the underside of the tranny mold I made. I made it by taping the whole tranny tunnel, carept and all, with painters tape, then spraying that with spray adhesive and laying down aluminum foil, then glassed to the foil, put down 2 layers and popped the mold out. I ripped alot of the foil off. Then I took the center console part I have been working with, positioned it, and glassed it to the tunnel mold. Next step is to smooth it all out and make it look like one piece, then trim some of the excess fiberglass and get a nice clean edge going....
Old Jun 13, 2008 | 10:05 AM
  #153
Q's 68's Avatar
Q's 68
Love this thread Awesome work.
Old Jun 13, 2008 | 04:56 PM
  #154
davidm_comp
Mixed up a batch of Rage Extreme and filled in the passenger side of the console.
Old Jun 15, 2008 | 01:35 PM
  #155
davidm_comp
Well, I f@#$ed up, didn't mix in nearly enough hardener into the Rage and it was still really soft 2 days later, so I scraped it out and mixed up a batch of duraglass and filled in the void, even sanded in the green stage and got it pretty smooth this time...
Old Jun 19, 2008 | 11:17 AM
  #156
davidm_comp
Jeez, I went to order some more duraglass & resin from USComposites, shipping was more than the products....should have some more progress early next week
Old Jun 19, 2008 | 11:09 PM
  #157
on1wheel01's Avatar
on1wheel01
Wow this is looking killer, I have been thinking about making a custom console but man this looks like a lot of work.
To Custom Fiberglass Dash / Interior
Old Jun 20, 2008 | 10:27 AM
  #158
davidm_comp
Thanks, and its really not as bad as it looks, fiberglass is pretty forgiving, if you make a mistake just cut out that section with a dremel and patch it up with some new glass.
  #159
davidm_comp
Thank You
Old Jun 21, 2008 | 01:21 PM
  #160
davidm_comp
Its like Christmas morning....I got some packages from the UPS man....
