Hooker sidepipe inserts
Old Feb 10, 2008 | 05:10 PM
Corbrastang's Avatar
Corbrastang
Here is a sound clip of my sweet-thunder inserts(2-1/4") on my 302/320rwhp cobra. I had Mike at Sweet-thunder fabricate the inserts to fit into my FFR pipes. They have a really awesome sound-much better than the glasspacks that i had previously. I lost 5rwhp, but it was worth it to me because my left ear was really starting to suffer.
http://s20.photobucket.com/albums/b2...ravideo003.flv
http://s20.photobucket.com/albums/b2...ravideo002.flv
Old Feb 10, 2008 | 05:53 PM
DZRick's Avatar
DZRick
Now you know why they are called Sweet Thunder.
Thanks for the clips.
Old Feb 10, 2008 | 06:14 PM
Corbrastang
Yes, they are certainly loud enough to grab attention, but they dont get anywhere near the obnoxious level, plus they have such a good tone. I added his larger diameter(2-1/4" ID) original style sidepipes to my 65 Corvette as well. They sound really good and arent nearly as loud as the blown out original style 1-3/4" ID pipes that i had on my car a few years ago. That plus they add hp since the originals were so restrictive. Funny, i remember when i first added the original sytle small Internal diameter sidepipes and i thought that i was gaining power over my original 2-1/2" undercar system. No no, i had no idea that the original sidepipes had that much smaller internal diameter. Thank goodness for people like MIke that improve the original designs.
I've looked at the hooker inserts, but i have only seen on style that has a funnel shaped entry. The rest have that extremely restrictive and poor designed entry-flat all around with the tip of the entry to the muffler sitting out 1". That has got to kill a lot of power over the funnel design.
Old Feb 10, 2008 | 07:32 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Max flos have a reasonably smooth inlet radius...
Old Feb 10, 2008 | 08:51 PM
Corbrastang
I wonder why hooker doesnt make a smooth transition for all of their inserts. I talked to a guy that installed the inserts in the pic above and he said he thought they were too quiet so he cut them in half. HOwever, he said that even after cutting them in half that they were still not as noisy as the glasspack inserts.
Old Feb 10, 2008 | 09:41 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Sound is a subjective thing, but I wouldn't describe the Maxflo mufflers as quiet. Before these I ran a pair of magnum 2 1/4" glasspacks. They weren't really louder, just different. The Hookers have the deepest tone of any of the inserts I've tried
Old Feb 10, 2008 | 11:10 PM
brngrhd's Avatar
brngrhd
how do they compair to 40 series flow masters?
Old Feb 10, 2008 | 11:58 PM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
Default sts
I purchased the STS baffles and hooker sidepipes last November and was worried that they might be too loud from the get go.They weren't at Idle but the engine came alive at acceleration.Last week I drilled a 1/2 hole in the center baffle tube and found what I was looking for.Worth every penny
Old Feb 11, 2008 | 12:44 AM
MakoShark72's Avatar
MakoShark72
Drilling the hole made them louder?
Old Feb 11, 2008 | 01:01 AM
redcruz1120
St. Jude Donor '09
Yes!! But just loud enough for me. If I wanted to go louder I could drill a bigger hole or just remove the cap that you're drilling into which is basically a freeze plug.Like I said I found my sweet spot with a half inch drilled hole.
Old Feb 11, 2008 | 07:16 AM
Bangkok Dean's Avatar
Bangkok Dean
I made my own twisters out of stainless steel.
Old Feb 11, 2008 | 08:28 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Can't say as I've heard 40s up close and in person....
Old Feb 11, 2008 | 11:48 AM
  #33
Corbrastang
Yes, but don't the swirl/auger type inserts have a tinging metallic sound??
Old Feb 11, 2008 | 11:57 AM
  #34
MakoShark72
Old Feb 11, 2008 | 01:12 PM
  #35
jcswm's Avatar
jcswm
Originally Posted by supervette77
I have Hooker sidepipe headers and maxflo's on mine and love 'em. They have a deep powerful sound without being too obnxious. I noticed a decent increase in throttle response from my L48 with them over the true duals that I was running before with 1-5/8" Summit full length headers.
Originally Posted by Scottys78
I have the Max flows in mine and I love them…They sound amazing (very loud)
Originally Posted by 79VetOwner
I had the reverse flows and hated them, then I bought the max flows from a fellow forum member and I love them.
I dont think the sound level is too bad but I put Dynamat throughout the entire car (all but the t tops) and it helped alot over what I have heard in other C3s.
I Love my max-flows perfect deep rumble at idle really shows off my "lopy" cam and it feels like it added a ton of hp after running open pipes for a year!! AND they keep the pipes MUCH COOLER... no more burning flesh
Old Feb 11, 2008 | 02:17 PM
  #36
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
[QUOTE=Bangkok Dean;1564043776]I made my own twisters out of stainless steel.
Purdy!
Old Feb 11, 2008 | 03:02 PM
  #37
69/03vette's Avatar
69/03vette
Thats the problem I have with my STS inserts. Had the max flows, way to loud. I guess I'll keep searching someone has to have one thats not to restrictive but sounds good.
To Hooker sidepipe inserts
Old Feb 11, 2008 | 04:43 PM
  #38
redcruz1120
St. Jude Donor '09
Not here!I think I would have noticed that already.
Old Feb 12, 2008 | 01:49 PM
  #39
Corbrastang
I'll let you know how my project turns out with the sweet thunder 29-1/4" length and 2-1/4" ID inserts.
I had heard from a few people that made special muffflers with DNA mufflers that they had a very specific metal sound. I've never heard a car with the auger inserts, so i have no first hand knowledge. MY experience and testing is limited to glasspacks, cc inserts, and sweet-thunder inserts thus far.
Old Feb 12, 2008 | 01:52 PM
  #40
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Originally Posted by sevnty7
Hi, New to the forum, nice site! This question is for the sidepipe guys out there, im currently running the 4" hooker set-up with the 1.78" inserts and i dont like them,too restrictive.im in a toss-up between the hooker 2.5" Max flows or the Sweet thunder 2.5" inserts. Anybody running the maxflows? are they too loud? im not looking into the spirals. i have a stock l48 vette. thanks for any imput.
I have the 2.5 Sweet Thunders, and can send you a wav file if you like.
cheers
tim
