69 427 Question
Old Jan 30, 2008 | 05:35 PM
fmfrm250's Avatar
fmfrm250
Default How to ID A 69 427 convertible
How do I determine if a 69 corvette convertible is a true 427 car if the numbers do not match. I was told there is not any paper work for the car? Other than restoration reciepts. Also does $7,100 seem pretty inexpensive to paint a 69 corvette? I have a 68 427 but it is numbers matching and I bought from the original owner my brother in law. So I never had to do any research. And I am not finding much info on how to ID it. thanks everyone.
Old Jan 30, 2008 | 08:18 PM
StickShiftCorvette's Avatar
StickShiftCorvette
There is nothing I know of that can't be faked, however, I would look for these signs:
The differential u-joints should have forged caps with bolts NOT u-bolts.
The tach redline should be 5600 or 6500
Large Brass Radiator
Original BB Hood
Old Jan 30, 2008 | 08:42 PM
dbeall1968's Avatar
dbeall1968
How good/bad is the paint? If the body is good, and doesnot require much prep, 7100 is reasonable. There are a lot of variables, and maybe the guy quoting needs to pay some bills, and you can get a break. PICS, PLEASE!
Old Jan 30, 2008 | 08:45 PM
onsturn's Avatar
onsturn
The code on the bottom of the differential should also have a 2 or 3 letter code for a Heavy Duty big block application. If you get the code post it and one of us will tell you what it means. All big blocks also had a rear sway bar.
Old Jan 30, 2008 | 08:46 PM
vettebuyer6369's Avatar
vettebuyer6369
Original BB Hood
...all of which, very easily installed at any time.
Without a tank sticker, you can't really tell. And given the fact that you don't have the original motor it doesn't really matter anyway.
Old Jan 30, 2008 | 09:29 PM
Corey_68's Avatar
Corey_68
So many clones and sadly even blocks are re-stamped these days, just as Pro-Team. So in short unless you have a tank sticker it's all hearsay...
Old Jan 30, 2008 | 11:33 PM
StickShiftCorvette
I think that is exactly how I prefaced the list......
Old Jan 30, 2008 | 11:35 PM
international blue's Avatar
international blue
Tank sticker means absolutly nothing. There is no vin number on the tank sticker and the only way to link it up is for the color trim tag to match as well as the grease pencil number on the pass footwell front with the number drawn on the sticker.
Many cars are built using tank stickers because if you have a trim plate repoped, the vin does not matter!!!
Old Jan 31, 2008 | 12:16 AM
17 4ever's Avatar
17 4ever
Original BB Hood
Old Jan 31, 2008 | 01:10 AM
fmfrm250's Avatar
fmfrm250
I am going down to Phoenix on Thursday. Thanks for the tips. Its SUPPOSIDLY an original 69 427 convertible without the orig motor. It is green with blk interior 4 speed. Supposidly the radio is hooked up and the fan is not hooked up either. They also said that its a part that allows the wipers to work? Some type of vacuum to open the cowl so the wipers can? I will find out tomorrow. They are asking 40 k. Pics soon.
Old Jan 31, 2008 | 01:39 AM
PizzenEwayMoney's Avatar
PizzenEwayMoney
40k?
Old Jan 31, 2008 | 10:26 AM
pws69's Avatar
pws69
WAY, WAY too much $$ (easily more than 2X) for a completely questionable NOM 69!!
If you have $$ to burn and love it, bless ya!
Old Jan 31, 2008 | 06:02 PM
StickShiftCorvette
Sounds way too high. Your description indicates it is NOT perfect. To be worth anything close to that it would need to be perfect AND have a mega buck engine - maybe an all aluminum BB with titanium rods.....
Old Jan 31, 2008 | 07:05 PM
DJordan442's Avatar
DJordan442
Originally Posted by PizzenEwayMoney
40k?
KEEP LOOKING
Old Jan 31, 2008 | 11:41 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
$40 K ???? maybe with the original motor.............
Dont even waste your time !!
Old Feb 1, 2008 | 12:15 AM
Ironcross's Avatar
Ironcross
Wiper doors are at top right.
To 69 427 Question
