rear spring bolts
Old Mar 1, 2008 | 10:31 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
Default rear spring bolts
i bought a set of rear spring bolts for my car cause they look pretty rusty and the bushings are dry rotted. my question is this a job i can do or leave it to the pros????
Old Mar 1, 2008 | 11:02 PM
TimAT's Avatar
TimAT
No trick. Set the car on stands- make sure it's solid. rear tires off. If you have a sway bar on the rear you need to unbolt it- there is a single bolt in 2 places on each side- I'd remove the lower one- it needs to come off anyway. Swing the sway bar up out of the way. there are 2 bolts that hold the bracket to the T/A, remove them and the plate they bolt into (these are over the to of the spring bolt). Put a "C" clamp on the spring and your jack just outboard of that. The clamp is so your jack can't slip out from under the spring. jack it up just enough to take the pressure off the spring bolt, remove the spring bolt and cushions. Replace- do it again for the other side.
Nothing to it..
Old Mar 1, 2008 | 11:12 PM
champs65's Avatar
champs65
Originally Posted by TimAT
Nothing to it..
Old Mar 2, 2008 | 01:43 PM
Alan 71's Avatar
Alan 71
TimAt is right on. You do have to be very careful when you unload the spring because there is a LOT of stored energy when its compressed.
Regards,
Alan
To rear spring bolts
