Behind the Tachometer
Old Mar 12, 2008 | 06:04 AM
Graemeinvette's Avatar
Graemeinvette
Default Behind the Tachometer
I have a little cannister (actuator?) bolted to the rear of my tachometer in my 1970, it has a vacuum hose and electrical wires attched. Whats its function and what is it called?
Graeme
Last edited by Graemeinvette; Mar 12, 2008 at 06:05 AM. Reason: Want to see replies
Old Mar 12, 2008 | 06:24 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
This is the wiper's door actuator solenoid.
Old Mar 12, 2008 | 07:16 AM
Graemeinvette
Thanks for that, now i can order a new one!
G
Old Mar 12, 2008 | 11:59 AM
PETKAH's Avatar
PETKAH
That solenoid is available from major cat houses - however, I've seen some priced at $80. (If this part is made in China cost is probably under $3.oo - but it is a hard to find part thus the price.) Do a search because some time ago - months - there was a thread on how to rebuild that piece.
Old Mar 12, 2008 | 12:40 PM
pbcanney's Avatar
pbcanney
good title for a book
Old Mar 12, 2008 | 02:05 PM
7T1vette's Avatar
7T1vette
Doesn't it function? It is merely a 12v solenoid switch that has a valve for passing vacuum. Test it first to make sure there is something wrong with it before you throw $80 at a new Chinese part. Many times the solenoid just gets "cruddy" inside and won't pass the vacuum. It may just need a good cleaning.
Old Mar 12, 2008 | 05:56 PM
Alan 71's Avatar
Alan 71
pbcanney,
When I read it I thought..." bad place to be".
Regards,
Alan
Old Mar 12, 2008 | 06:40 PM
Duke94's Avatar
Duke94
Not very complicated. Put 12VDC to the coil and listen for the click. Use a hand vacuum pump (you have one right?) to check for leaks.
Old Mar 13, 2008 | 08:27 AM
69ttop502's Avatar
69ttop502
A related question. I have one of these off of a car I parted out and the two terminals are broken off. If I take it apart is there a way to fix that. It seems they were just held by a very small "corner". Thanks for the help before I take it apart.
Bill
Old Mar 13, 2008 | 08:29 AM
pbcanney's Avatar
pbcanney
Originally Posted by Alan 71
pbcanney,
Regards,
Alan
Old Mar 13, 2008 | 08:37 AM
Graemeinvette
I'm replacing it because it leaks vacuum. I also have to take the rev counter out since the other day the needle fell off (long story!) so I figured why do trial and error when I can replace it for $45. Once the old ones out I will sort the leak and keep it as a spare.
Thanks for all your help guys.
Graeme
Old Mar 13, 2008 | 08:41 AM
Duke94's Avatar
Duke94
Bill
If the 2 terminals are broken off, it might be junk. The coil is connected to these two terminals which are molded into the coil bobbin. The 2 terminals need to be insulated from each other.
Old Mar 13, 2008 | 12:24 PM
69ttop502's Avatar
69ttop502
Thanks Duke, I was afraid that might be the case.
Bill
Old Mar 13, 2008 | 12:30 PM
7T1vette's Avatar
7T1vette
The only feedback I would add is this.... The original part lasted well over 20 years before it malfunctioned; and it is probably only dirty. If you get it cleaned up, it will likely work well for another 20 years. A "modern" replacement will not be made to last nearly as long. So you can install a new one which may last 5 years; or you can clean up the old one [assuming there isn't any permanent damage when you check it out after cleaning], put it back in, and probably never hear from it again. Your choice.
To Behind the Tachometer
