Battery disconnect location
Old Apr 5, 2008 | 03:38 PM
awest5321's Avatar
awest5321
Default Battery disconnect location
Looks like a lot of you guys use a battery disconnect. Where is a good place to put the disconnect switch in a C3 vette? Close to the battery would be best I imagine but inside the battery box would be difficult to reach every time I want to drive or stop. Maybe behind the seat in the riser panel? Where do other members have it located?
Old Apr 5, 2008 | 03:44 PM
irvan's Avatar
irvan
My 74 has one that was in it when i bought it. It's right on the battery terminal and you have to lift up the lid with the seat back tilted forward to get at it. I forget about it and never remember to turn it off so is not a problem for me.
Old Apr 5, 2008 | 03:47 PM
Theiskell's Avatar
Theiskell
Mine is mounted between the seats. It’s easy to get to and when you pull the key out it’s basically invisible.
Old Apr 5, 2008 | 04:17 PM
another-user's Avatar
another-user
mines one the bat. terminal. only takes an extra 10 seconds to turn it on.
Old Apr 5, 2008 | 04:38 PM
DvBoard's Avatar
DvBoard
Do most people have these to keep from draining the battery, or security?
Old Apr 5, 2008 | 04:59 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Simplest place I found was the center storage compartment, battery side....
Old Apr 5, 2008 | 05:01 PM
another-user
mostly just to keep from draining the battery on mine, but the added security is a nice touch.
Old Apr 5, 2008 | 05:12 PM
7T1vette's Avatar
7T1vette
Both. It is very convenient to shut down power when working on the car. Also nice for security for the car; that's why I left it in the battery box...so I can lock it, too, if needed.
Old Apr 5, 2008 | 05:24 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I welded up a little bracket to put a key-type switch in the front of my battery compartment where the positive cable comes in. It can only be easily found by touch.
Old Apr 5, 2008 | 05:31 PM
thrilher's Avatar
thrilher
in my '79 there was a perfect about 3/4" hole right behind the passenger seat coming out of the storage area.i shimmed it out with i think 3/4" plywood so it would'nt protrude out too far and secured it in.
Old Apr 5, 2008 | 05:48 PM
Alan 71's Avatar
Alan 71
The main reason I have my disconnect is so I don't have to worry about an electrical fire while the car AND I are sleeping.
Regards,
Alan
Old Apr 5, 2008 | 07:30 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Regards,
Alan
That was my motivation
Old Apr 5, 2008 | 08:12 PM
69 Convertible's Avatar
69 Convertible
Mine is on the battery terminal. That's how I got it. I like it like others have said, in case of battery drain and not having to worry about electrical short leading to fire. And having it close in case when your driving and you see and smell smoke, you can pull over and then disconnect it quickly so no further damage will occure. Tony
To Battery disconnect location
