79 rubbing sound
Old 04-11-2008, 01:49 PM
wmkj69
wmkj69's Avatar
Default 79 rubbing sound
my 79 sounds like something is rubbing on the drive shaft or the axles, but nothing is there. IDEAS?
Old 04-11-2008, 02:17 PM
cm-smith
cm-smith's Avatar
Default Brakes
Could it be brakes dragging, or worn to the metal? Is it a constant noise, or sort of a clink clink? U-Joints gone dry or bad is another possibility.
Old 04-11-2008, 02:19 PM
justaguy10825
justaguy10825's Avatar
Can't say for sure if it is the same but my 78 was making a "metal rubbing" sound everytime I moved the car in forward or reverse... It was coming from the right rear... I jacked the car up and could not see a darn thing that looked like it should be making noise when I spun the wheel by hand... I pulled the rotor off & found that one for the parking brake springs had broke on one end and had worked it's way between the brake shoe and the rotor... "No-more noise"
Old 04-11-2008, 04:10 PM
marshrat99
marshrat99's Avatar
When does the noise occur? During turns, breaking, etc?
Old 04-11-2008, 04:12 PM
bkerlee
bkerlee's Avatar
St. Jude Donor '05
I took my '79 into the shop for an oil change and lube job, and all the noises stopped. Might do that.
Old 04-11-2008, 07:27 PM
Duke94
Duke94's Avatar
Check to see if the e-brake cable is rubbing the inside of the tire. It comes real close especially if you have one size bigger tire.
Old 04-11-2008, 10:30 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Quite often it’s the parking brake hardware. A spring will break inside and drop down and rub the brake rotor.
This sound is nothing to fool around with though. It’s getting warmer outside and people are driving the cars with the windows down and the tops out!
Other things to check: Rear wheel bearing clearance, U-joints and as mentioned above the parking brake cable rubbing.
Willcox Inc.
Old 04-11-2008, 11:18 PM
El'Choppahead
El'Choppahead's Avatar
rubbing,...
I have an noise, it is indeed the E-brake cable under certian stress it'll rub,.
also,.. if your diff dose not have posi-diff lube it will indeed make lots of rubbing sounds,.. a good flush and proper GM posi-diff treatment will prolly fix er for ya!
Old 04-12-2008, 10:28 AM
wmkj69
wmkj69's Avatar
I've had both wheels off the rear end, checked, and all looks fine. The noise is mainly when I accelerate. it sounds like metal rubbing on metal. It sounds like rit,rit,rit,rit! Like them sound effects. I need more help, PLEASE.
Old 04-12-2008, 12:10 PM
Lon Wayne
Lon Wayne's Avatar
Default Vader Vette
Hey like Choppahead said have you tried the GM lube and the rear end oil change ? it will make a noise like Something in the drive shaft My 77 use to do it after I would get the rear end up to temp the back end would start cherning like it was mixing somthing up back there,did the rear end grease and the 2-Bottles of special lube and presto the clutches in the rear end turned fine and never made the noise again .do the easy things FIRST.
To 79 rubbing sound
Quick Reply: 79 rubbing sound
